Moment independent of direction of force?
The discussion revolves around the concept of torque in relation to the direction of force and the lever arm. Participants explore the mathematical and conceptual aspects of torque, including the significance of vectors and the implications of coordinate systems on calculations.
  • Some participants argue that torque is dependent on both the direction of the lever arm and the direction of the force, emphasizing that neglecting direction leads to incorrect conclusions.
  • Others suggest that distance can be treated as a scalar, questioning the necessity of considering direction when discussing torque.
  • A participant reflects on the relativity of direction in their calculations, acknowledging that while their perspective changes, the direction of force remains constant for the pivot point.
  • There is a discussion about the representation of torque as a pseudovector in three dimensions and the use of the right-hand rule to determine its direction in a two-dimensional context.
  • Some participants express confusion regarding the distinction between distance and displacement, with one asserting that distance should not be treated as a vector.
  • Another participant clarifies that torque is defined using the cross product of the lever arm vector and the force vector, reinforcing that displacement, not distance, is relevant in this context.
Participants do not reach a consensus on the treatment of distance versus displacement in the context of torque calculations. Multiple competing views remain regarding the significance of direction and the nature of the vectors involved.
The discussion highlights limitations in understanding the definitions of distance and displacement, as well as the implications of different coordinate systems on torque calculations. Some mathematical steps and assumptions remain unresolved.
dE_logics
There's a PDF attached to this; have I concluded things the right way?
First, you are not applying the force radially, there is no radial component in your diagram if you take the pivot/fulcrum to be your origin. The torque is dependent upon the direction of the lever arm and the direction of the force, so you can't neglect sign or direction (the latter is what you have neglected). The reason why the torque is in the same direction for both is because you are applying the force in the same direction with relation to the lever arm.
The main problem is that you are using an incorrect equation for the torque, the torque is a vector that is the lever arm cross the force.
Yeah I was thinking about that, but it's just a distance...I mean, its just the magnitude of displacement...it's like taking a measured section of a scale...that doesn't have a direction.
Humm...so actually it is relative. Its for me that the direction is changing...as a result I'm taking it as the modulus.
But actually its not changing for the point around which I'm trying to calculate the torque...so for that point, the direction of force will remain a constant.
Am I right?
dE_logics said:
Yeah I was thinking about that, but it's just a distance...I mean, its just a displacement...it's like taking a measured section of a scale...that doesn't have a direction.
What is just a distance? There are two interesting vectors in your picture. The first is the vector from the fulcrum/pivot to the point where the force is applied to the beam. (If we conveniently chose the fulcrum to be the origin of our coordinate system, then that vector would just be the position vector of the point on the beam that's getting pushed. But regardless of the coordinate system we choose, it's still a vector.)
The second vector is the force itself. Force is a vector, having both a magnitude and a direction.
The torque, whether clockwise or counter-clockwise, and its magnitude, depends on both of these vectors.
In space (3 dimensions), we represent torques as pseudovectors, and we take the cross product of the two vectors I mentioned. In the plane, it's simpler because torques can only be clockwise or counterclockwise. It's a bit like having a vector in only one dimension: a magnitude and a sign.
It works like this in the plane... Stand on the fulcrum and look in the direction of the vector towards where the force is applied. Now consider the direction of the force vector. If it's pointing to your left, then your torque is counterclockwise. If it's pointing to the right, then your torque is clockwise. The point is that you need both vectors to get the magnitude and orientation of the torque. (By the way, this is called the "right hand rule" restricted to the plane.)
I'm still having problems with that first vector...the distance.
Ok, you took a coordinate system, that way, only the 'point' will be called negative, but not the distance from the fulcrum...that is still a distance...not a displacement. Ok...suppose we change the coordinate system to one end of the bar being rotated, i.e that end will be called as 0...then every point will be negative or positive...same is case when the torque is computed taking a coordinate system which's 0 at a point out of the bar.
Thanks for clearing that second force problem Cantab Morgan + Born2bwire. But after clearing the second problem, the first problem will persist even more. If we do take the distances as vectors, then considering we take the force as a vector too...things cancel out...it will mean the same thing as taking the modulus.
The distance also has to be taken WRT the rotating point to fix this problem i.e if we are somehow taking distance as a vector. That way there will be just one sign of distance and force throughout the rotation.
We are not taking distance, we are taking the vector describing the lever arm. Distance is only a scalar.
But why is the distance vector?...how can it be a vector?
The torque resulting from some force F applied at some point p is defined as [itex]{\boldsymbol N} = {\boldsymbol r}\times{\boldsymbol F}[/tex] where <b>r</b> is the displacement <i>vector</i> (not distance) from the fulcrum to the point <i>p</i>.<br /> <br /> In short, it's not distance (which is a scalar) that is involved here, it's a displacement vector.[/itex]
Ok...thanks!
  • · Replies 67 ·
  • · Replies 54 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 93 ·
