Thread Closed
distance to stars from my house using the parallax technique?
Share Thread Thread Tools
May30-09, 02:41 PM   #1
Is it possible to find the distance to stars from my house using the parallax technique? If I can how close does a star have to be to be measured in a month instead of six months?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
May30-09, 03:30 PM   #2
Recognitions:
Quote by Stratosphere View Post
If I didn't know any better I'd say you were trying to do this yourself.
A star at a distance of 1 pc displays a parallax of 1 arcsecond. There are no stars closer than 1pc, so even the nearest are going to display a parallax siginificantly smaller than 1 arcsecond. And these are annual parallax numbers. If you want to try the measurements in only a month, you can expect much smaller parallaxes, on the order of 1/50 of an arcsecond for typical stars.
So, unless you have that kind of resolving power, I'd say it's out of the question.
May30-09, 04:30 PM   #3
So would I be able to measure things that would require a longer amount of time?
May30-09, 06:42 PM   #4
Recognitions:
Probably not. Like I said annual parallaxes are going to be less than one arc second. Significantly less, but it's probably even optimistic to hope to get some in the neighborhood of 1/10 of an arcsecond. Annually. Also, given the fact that even under the best of seeing conditions the earth's atmosphere limits resolution to about .5 arcseconds, it seems a daunting task indeed.
Getting down to .5 arcseconds isn't actually that hard, and only requires a ~8-10 inch diameter telescope. But taking precise enough measurements to detect the parallax, owing to the damned atmosphere, would be near impossible for an amateur (I think).
May30-09, 10:17 PM   #5
Recognitions:
Gold Membership Gold Member
You can do the math with simple trigonometry. The diameter of the earths orbit around the sun is approximately 186 million miles [a very convenient number - 1000 light seconds]. That forms the base of the parallax triangle you have to work with. One light year works out to around 6 trillion miles - a pretty large number compared to the diameter of earths orbit. You need a very accurate [and expensive] devise to reliably measure such small angles.
May30-09, 11:03 PM   #6
OK, these answers are better than mine. Which was going to be 'Depends on how wide your house is'.
Thread Closed
Thread Tools
Similar Threads for: distance to stars from my house using the parallax technique?
Thread Forum Replies
Using parallax and magnitudes. Astrophysics 1
Advantage of measuring stellar parallaxes from Mars rather than Earth? General Astronomy 2
Parallax Problem General Astronomy 0
parallax questions Cosmology 1
Parallax and Kepler General Astronomy 6
