Fourier Transform of cos(2*pi*t)
The Fourier Transform of cos(2πt) results in delta(1) + delta(-1). By substituting into the Fourier Transform formula and utilizing Euler's formula, the integral of the product of two trigonometric functions yields non-zero values only when their frequencies match, specifically at F = 1. The integral of two different frequency functions equals zero, confirming the non-zero result at these specific delta functions. This conclusion is essential for understanding the behavior of Fourier Transforms in signal processing.
  • Understanding of Fourier Transform concepts
  • Familiarity with Euler's formula
  • Knowledge of trigonometric identities
  • Basic calculus, particularly integration techniques
  • Study the properties of the Fourier Transform in detail
  • Learn about delta functions and their applications in signal processing
  • Explore trigonometric identities and their proofs
  • Practice solving Fourier Transform problems using different functions
Students and professionals in mathematics, engineering, and physics who are learning about Fourier Transforms and their applications in analyzing periodic functions.
BriWel
I have a practice question, which is to find the Fourier Transform of cos(2^pi^t)
By substitution into the FT formula, and use of eulers formula,I have managed to reduced to:
INTEGRALOF ( (cos(2*pi*t) * ( cos(2*pi*F*t) - j*sin(2*pi*F*t) ) )
By plotting the frequency graph of the original function, I know that the answer I am looking for is: delta(1) + delta(-1)
I have also been told that the integral of two trig functions multiplied together equals 0 if the functions have different frequencies. This indicates that the above formula is only non-zero where F = 1.
My problem is that I don't know how to get from the above formula to delta(1) and delta (-1). Can anybody help?
Also, I'm relatively new to Fourier Transforms, so as much detail as possible in answers will be appreciated!
thanks in advance for any help
Welcome to PF!
Hi BriWel! Welcome to PF! :smile:
(have a pi: π and a delta: δ and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
You need to learn your https://www.physicsforums.com/library.php?do=view_item&itemid=18"
in this case, 2cosxcosy = cos(x+y) + cos(x-y) and 2sinxcosy = sin(x+y) + sin(x-y) …
and then you should be able to prove that the ∫0 is 0 unless x = ±y :wink:
