Need help on determining the size and type of fluid pickup pump
  • Thread starter Thread starter BernieM
    Fluid Pump Type
The discussion revolves around determining the appropriate size and type of fluid pickup pump for a solar concentrator system utilizing mineral oil and R113 (later changed to R123) as the working fluid. Participants explore the calculations needed for flow rates and pressures in the system, as well as the implications of using an automotive radiator as a condenser.
  • One participant describes the solar concentrator setup, including the materials and efficiencies involved, and outlines the operational parameters of the system.
  • Another participant questions the use of an automotive radiator as a condenser and asks for potential issues related to this choice.
  • A third participant suggests using steam tables for the working medium and emphasizes the need to calculate energy production and flow rates based on temperature differences.
  • A later reply indicates a decision to switch from R113 to R123 due to cost and environmental concerns, providing a link to relevant data on R123.
Participants express differing views on the choice of refrigerant and the design of the condenser, indicating that multiple competing views remain regarding the optimal setup for the system.
Participants have not yet resolved the calculations for flow rates and pressures, and there are assumptions regarding the efficiency of the system that may depend on specific conditions not fully detailed in the discussion.
Individuals interested in solar energy systems, fluid dynamics in thermal systems, and those exploring alternative refrigerants in engineering applications may find this discussion relevant.
BernieM
I have 5 Solar Concentrator panels I have built with a 1 meter wide by 3 meter long footprint each. The solar absorber tubes are 3/4" Type M Copper piping that is black chrome coated (98% absorptivity) surrounded by a borosilicate glass envelope (92% transmissivity).
There is a hard vacuum between the absorber pipe and the glass (10^-9 Torr), virtually eliminating convective losses and since borosilicate transmits short wavelength IR very well and reflects long wave IR there is almost no radiation losses of heat either.
The reflectors are made of aluminized mylar with an efficiency of 97%. The over all efficiency (theoretical) is approximately 87%. Distance between solar panels and boiler is very short (less than 3 meters) so not much heat is lost in fluid transport to the boiler, so overall efficiency reaching the boiler should be around 75% to 80% of input energy. Piping is insulated.
The operating temperature of this system will be about 260C. Solar input is per available sun near Phoenix, AZ.
Mineral oil will be circulated through it to a small boiler (approximately 7 gallons in size) with a heat exchanger inside it. The working fluid in the boiler is R113 (boiling point of approximately 48C), which when vaporized will go through a 5 hp air motor then to a radiator which will be bathed in a flow of cool water (20C).
The condensed R113 will then be picked up and pumped back into the tank.
Here is the problem:
I do not have the know-how or education to calculate the flow rates of the freon through the system and figure out what kind and size of pump i need to use to pick up the freon flowing through the system.
In addition, I am planning to use an automotive radiator bathed in a shower of cold water as the condenser. Does anyone see any significant problem with this?
You need steam tables for your working medium. Figure out how much energy your collectors are going to produce, and also your hot and cold temperatures. After that you just have to do the math to find out how much flow and at what pressure. I'll see what I can do to help tommorow when I get home, as I'm at work now.
  • · Replies 40 ·
