Double integral for area evaluation
The discussion revolves around evaluating the area bounded by a specific curve using a double integral and a trigonometric substitution. The curve is defined by a complex equation involving both x and y coordinates, and the participants are exploring the implications of their chosen substitution.
  • The original poster attempts to use a trigonometric substitution to express the curve in polar coordinates but encounters issues with the range of theta being segmented. They question how to establish a continuous range for theta suitable for integration.
  • Some participants suggest integrating over separate ranges and combining the results, proposing that fewer intervals might simplify the process.
  • There is a clarification regarding the correctness of the substitution used, with one participant pointing out a potential error in the original poster's formulation.
The discussion is ongoing, with participants providing suggestions on how to approach the problem of integrating over segmented ranges. There is an acknowledgment of a mistake in the substitution, which the original poster plans to correct. No consensus has been reached yet, and multiple interpretations of the substitution and integration ranges are being explored.
The original poster assumes that the parameters a and b are greater than zero, which may influence the behavior of the curve and the integration process. There is also a note of the need for a continuous range for theta to facilitate integration.
LeifEricson
Use an appropriate double integral and the substitution
[tex]y = br\sin \theta \text{\ \ \ } x = ar\cos \theta[/tex]
to calculate the bounded area inside the curve:
[tex]{\left( \frac{x^2}{a^2} + \frac{y^2}{b^2} \right)}^2 = \frac{x^2}{a^2} - \frac{y^2}{b^2}[/tex]
(you can assume that [tex]a,b > 0[/tex])
I began with the substitution and I got the following representation of the curve:
[tex]r = \sqrt{ \cos^2 \theta - \sin^2 \theta }[/tex].
That means that [tex]0 \leq r \leq \sqrt{ \cos^2 \theta - \sin^2 \theta }[/tex].
Now I have to find from where to where [tex]\theta[/tex] goes. But according to the polar representation I get a very segmented range which is:
[tex]0 \leq \theta \leq \pi / 4 \text{\ \ \ } 7\pi / 4 \leq \theta \leq 2\pi \text{\ \ \ } 3\pi / 4 \leq \theta \leq 5\pi / 4[/tex]
And this is a problem because I need [tex]\theta[/tex] to range in a continuous range. So it can be used as a boundaries of an integral.
So what should I do?
Edit:
Fixed substitution. It was x = [tex]br\cos \theta[/tex] instead of what it is now.
You can integrate over the ranges separately and then add them. No law against that. It might be easier to do two ranges [-pi/4,pi/4] and [3pi/4,5pi/4] rather than three. You might also notice your r^2=cos(2*theta), so it should be pretty clear you are going to get the same result on each of those two intervals.
Are you sure that the substitution is as you wrote it? That seems to be what you actually used.
Assuming that's the case, you'll get r2 = cos2(theta) - sin2(theta) = cos(2theta).
Oh no!
You are right.
The substitution I wrote is a mistake.
I will edit my post to fix that.
  • · Replies 19 ·
  • · Replies 20 ·
