Solving the Coefficient of x^33 in Binominal Theorem Expansion
  • Thread starter Thread starter morbello
    Theorem
The discussion revolves around finding the coefficient of x^33 in the expansion of the expression (1/4 + 2x^3)^17 using the binomial theorem. Participants are exploring the necessary conditions for the term involving x^33 to appear in the expansion.
  • Exploratory, Assumption checking
  • Participants are attempting to determine the appropriate value of k that will yield the x^33 term in the binomial expansion. There are questions about how to derive k from the given expression and the implications of different values of k on the resulting terms.
The discussion is active, with participants sharing their thoughts on how to approach the problem. Some have suggested considering specific values for k to identify which will produce the desired term, while others express uncertainty about the calculations and the underlying concepts.
There is a mention of confusion regarding the application of the binomial expansion formula and the relationship between the terms involved. Participants are also reflecting on their understanding of the binomial theorem and its components.
morbello
ive been asked to work out the coefficient of x^33 in the expansion of
(1/4 2x^3)^17
i know about (a+b) and ^C_ but I am unsure how to get k which is c_k
i worked off (1/4)^17-k (2x^3)^k
which give me 17*1/4 =4 1/4 and that is were i went wrong could you tell me a way to work out k
What is the only value of k that will produce the x^33 term?
so your saying some thing as simple as -16 would make the sum work.
Im not sure how you got -16.
The binomial expansion formula says that:
[tex](0.25+2x^3)^{17} = \sum \!^{17} C _k (0.25)^{17-k} (2x^3)^k[/tex]
As k ranges from 0 to 17. For which of those values of k will the x^33 term appear?
that is what I am not sure about i don't know an easy way to find k
Ok, well consider a few different values for k.
If k=1, then the (x^3)1=x3 term will appear. If k=2, then the (x^3)2=x6 term appears. Can you see now what value of k will make the x^33 term appears?
ok i see what you mean i did see a pice in the book about it but i was not sure what it ment.thank you i was thinking that both a+b worked together and did my maths around that i see i could look at it as b on its own.
