How Does Geometry Clarify the Concept of Gauge Fields in Physics?
  • Context: Graduate
  • Thread starter Thread starter jdstokes
    Fields Gauge Geometry
The discussion centers around the geometric formulation of gauge field theory, exploring the nature of gauge fields as connections in principal bundles and their relationship to vector bundles. Participants examine different interpretations of gauge fields, local trivializations, and gauge choices within the context of differential geometry.
  • One participant describes gauge fields as connections for principal bundles, linking them to gauge groups and associated vector bundles.
  • Another participant references John Baez's perspective, which defines gauge fields as connections for G-bundles, questioning the necessity of principal bundles in this context.
  • A participant suggests that understanding different gauge possibilities requires a global gauge function, rather than starting from local conditions.
  • One participant proposes that defining a gauge choice on a spacetime patch as a section of a local trivialization of the principal fiber bundle may be a more coherent approach.
  • Another participant agrees that changing local trivializations corresponds to gauge transformations, emphasizing the role of smooth transition maps in this process.
Participants express differing views on the definitions and implications of gauge fields and gauge choices, indicating that multiple competing interpretations remain without a consensus.
Some discussions hinge on the assumptions regarding the nature of bundles and the conditions under which local and global gauge choices can be made, which remain unresolved.
jdstokes
Recently I've been trying to understand the geometric formulation of gauge field theory.
The mantra I've been hearing is that a gauge field is a connection for a principal bundle where the structure group corresponds to the gauge group. Fields which are charged under the gauge group form sections of associated vector bundles.
John Baez's book has a slight different take, however, in which he essentially defines the gauge field as the connection for a G-bundle, which is vector bundle obtained by gluing together trivial bundles subject to G-identifications on the overlaps, what need then for the principal bundle?
I'm also grappling with the idea that a choice of gauge corresponds to a local trivialization. The idea seems to be that sufficiently small regions of the bundle are diffeomorphic to the product [itex]U \times F[/itex] where F is the typical fiber. I don't quite see how the different gauge possibilities arise out of this, however.
Thanks.
Regarding you last remark "I don't quite see how the different gauge possibilities arise out of this". I think one can't see that. One has to chose a global gauge function and check if it induces the correct local gauge sections. The other way round, namely to start with a local condition and try to "globalize" it may work if you have a trivial bundle,but in general it will not work.
Regarding Baez's book: I am not familiar with these ideas.
Well, in my opinion it would make more sense to define a gauge choice on some spacetime patch as a section of a local trivialization of the principal fiber bundle.
Is this the correct way of thinking about it?
garrett said:
This might help:
http://deferentialgeometry.org/#[[fiber bundle]]
Or it might just hurt -- but then the references at the bottom might help.
I think I can see where this is going.
It makes sense to me that changing the local trivialization corresponds to a gauge transformation since it is assumed from the outset that the fibers are sewn together using smooth (group-valued) transition maps.
If I want to do a gauge tranformation on some specified patch, then I need to figure out another way of assigning a local trivialization to that patch. But since I am working with a vector bundle with structure group G, the only way I know how to do this is to do a continuous G-tranformation of the fibers.
Suppose that I want to do a gauge transformation on
  • · Replies 26 ·
  • · Replies 61 ·
11K
