Photon/particle's energy in General Relativity
The discussion revolves around the relationship between energy and momentum of photons in the context of General Relativity (GR), specifically examining whether the Special Relativity (SR) relationship E = p holds true in GR. Participants explore the implications of the metric tensor on these quantities and the concept of the speed of light in various frames, as well as the interpretation of comoving distances in cosmology.
  • Experimental/applied
  • One participant questions whether the relationship E = p for photons in SR is valid in GR, suggesting that energy and momentum may need to be redefined in terms of the metric tensor.
  • Another participant emphasizes the importance of defining physical quantities independently of coordinates, noting that g_{00} lacks meaning without a specific coordinate system.
  • There is a discussion about the energy of a photon in a generic coordinate system, with one participant asking how the quantity g_{ij}P^iP^j relates to the energy of the photon.
  • Participants explore the implications of the speed of light being constant only in inertial frames and the concept of comoving distances in cosmology, questioning the physical interpretation of distances traveled by photons.
  • One participant points out that the frequency of a light wave as measured by an observer depends on the observer's four-velocity and the wave vector, raising questions about the observer's motion relative to the photon.
  • There is a mention of the square of the photon's energy being related to g_{ij}P^iP^j when indices represent components in an observer's orthonormal frame.
Participants express differing views on the definitions and implications of energy and momentum in GR, particularly regarding the role of the metric tensor and the observer's frame of reference. The discussion remains unresolved, with multiple competing perspectives on these concepts.
Participants note that the interpretation of physical quantities may depend on the choice of coordinates and the specific observer's motion, leading to ambiguity in defining energy and momentum in GR.
This discussion may be of interest to those studying General Relativity, cosmology, or the foundational aspects of energy and momentum in physics, particularly in relation to the behavior of light and observers in curved spacetime.
coccoinomane
Hi everybody!
I am wondering, among other things, whether the Special Relativity relationship E = p for a photon (I am using c = 1 units ) is still valid in General Relativity.
Let me explain my question in detail. By applying the null geodesic condition with a diagonal metric, we obtain
[tex]ds^2 = 0 \Rightarrow p^2 = -g_{00}(P^0)^2[/tex] (1).
where [tex]P^\mu[/tex] is the four-momentum and [tex]p^2 \equiv g_{ij} P^i P^j = P^i P_i[/tex].
My question is: in SR we did not have any doubt in identifying P^0 as the energy of the particle. How does it transfer to GR? What is energy and what is momentum? My shot was that, if we want to preserve the E = p relation, then we need that
[tex]p \rightarrow momentum[/tex]
and
[tex]\sqrt{-g_{00}} P^0 \rightarrow energy[/tex].
Is this correct?
And what about velocity?
It is easy to find that
[tex]v^i = \frac{P^i}{P^0}[/tex],
where [tex]v^i \equiv \frac{dx^i}{dt}[/tex].
If we contract both sides of the above expression with [tex]g_{ij} v^j[/tex] and if we define [tex]v^2 \equiv g_{ij} v^i v^j = v^i v_i[/tex], we find that
[tex]p = (P^0) v[/tex]. (2)
By comparing (1) and (2) it emerges that
[tex]v^2 = -g_{00}[/tex].
In a flat space-time (or in an inertial frame), then [tex]g_{00} = -1[/tex] and v = c. Otherwise we have that the speed of light is different from c. Does it mean that in GR the concept of "constant speed of light" makes sense only in inertial frames? This is equivalent to say that the speed of light is equal to "c" only locally, since for the equivalence principle we can always find an inertial frame, but it has to be locally defined (in a space-time sense).
One last question. With respect to Cosmology, one usually defines the comoving distance as the distance covered by a photon in the comoving frame. The particle horizon is the comoving distance from the Big Bang to today; by using a LCDM model it amounts to around 14.000 Mpc. I always thought that this was some sort of non-physical distance since it is the distance the photon traveled in a reference frame decoupled from the expansion. I was thinking that the "physical" particle horizon was just the age of the Universe times the speed of light, i.e. around 4.500 Mpc. Now I see that this is not the case. In fact, there is no such a "physical" frame in which the speed of the photon is constantly equal to "c" along all his path, hence it makes no sense to say that it "physically" traveled speed_of_light X time_of_travel kilometers. Am I right?
Thank you very much for any answer, and sorry for the long post :)
Cheers,
Guido
Hi atyy,
thank you for your answer!
The link seems very interesting. However, I was hoping you could point some intuitive physical argument, not a mathematical one.
Cheers,
G.
If you want values for physical quantities, make sure to define them independent of coordinates. g00 doesn't have a meaning at all, unless your coordinate system is defined in a specific way.
For a light wave with wave vector k, the frequency (energy/h) measured by an observer with four-velocity u is [tex]f=-u_a k^a=-g_{ab}u^bk^a[/tex].
Hi Ich,
thank you for your answer.
This is the point: I would like to know what is the energy of the photon in a generic system of coordinates in which the metric is described by [tex]g_{\mu\nu}[/tex]. Is it [tex]g_{ij}P^iP^j[/tex]? (sum is over spatial indexes)
Is the implicit summation over 0,1,2,3 or just over the spatial indexes? In the latter case, wouldn't we have f=0 if the observer is still?
With respect to which observer?
Hi George,
you are perfectly right, my question does not makes sense without specifying the observer's motion with respect to the photon. So I guess the correct answer is Ich's:
[tex]f=-u_a k^a=-g_{ab}u^bk^a[/tex],
because it takes into account that. However, I am curious about the quantity
[tex]g_{ij}P^iP^j[/tex].
How does it relate with the energy of the photon?
Thank you,
Guido
This is always the square of the photon's energy when indices represent components with respect to the observer's orthonormal frame. Unfortunately, many courses and texts put little or no emphasis on frames. I hope to write more about this (maybe tomorrow).
For an example of the use of frames for physical speeds, see
https://www.physicsforums.com/showthread.php?p=848684#post848684.
  • · Replies 36 ·
  • · Replies 76 ·
  • · Replies 71 ·
  • · Replies 50 ·
