How do I find the line of action of this resultant force?
The discussion revolves around determining the line of action of a resultant force derived from three applied forces on a body. The forces and their application points are specified, and participants are exploring how to find the intersection of the line of action with the Y-axis.
  • Mixed
  • Participants discuss calculating moments about the origin using the components of the forces. There is a question about the validity of assuming the resultant force is applied at a specific point on the Y-axis. Some participants inquire about the method for calculating moments and the implications of their assumptions.
There is ongoing exploration of the assumptions regarding the application point of the resultant force and its moment about the origin. Some guidance has been offered regarding the consistency of signs in calculations, but no consensus has been reached on the assumptions or methods being discussed.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There are also questions about the correctness of calculations related to moments and the resultant force.
aps0324
Three forces are applied to a body. They are :
F1 = (4,5) applied at (1,2)
F2 = (2,-1) applied at (3,-1)
F3 = (-3, 2) applied at (-2,1)
i) Find the resultant force
Answer : R = (3,6)
ii) Find the total moment about the origin
(This i know how to do)
iii) The line of action of R cuts the Y-axis at (0,d). Find d
iv) Find the equation of this line of action
How do I solve iii) and iv)
Did you try calculating the moments about the origin from the the x and y components of the forces separately? Then you can find a set of coordinates through which the resultant passes ([tex]X = \Sigma{(F_y(x))}/R_y[/tex], etc.), the slope of which resultant is R_y/R_x.
Is this assumption correct? (force vectors and moment)
Answer : R = (3,6)
Answer: I calculated this and it is -5 Nm
Question: Can I assume that R = (3,6) is applied at (0,d) and its moment about the origin is - 5Nm? In order to find what d is?
If that assumption is wrong then how do i find d?
F3 = (-3, 2) applied at (-2,1)i) Find the resultant force
Answer : R = (3,6)
Can you show your work on determining the moment in part ii)?
Isn't it the cross product of the F X r ?
Doesn't that yield
(4*2 + 5*1) + (2*(-1) + (-1)*3) + ((-3)*1 + 2*(-2)) = ... but ≠ -5
I merged two duplicate threads.
Yeah, as long as you are consistent with your plus and minus signs, that is to say, is d on the positive or negative y axis?
  • · Replies 20 ·
  • · Replies 25 ·
