Fixing Fortran DO Command Errors for Visual Fortran (f90)
  • Context: Fortran
  • Thread starter Thread starter zandria
    Fortran
The discussion revolves around errors encountered in a Fortran program, specifically related to the DO command and variable declarations in Visual Fortran (f90). Participants explore issues with variable definitions and the implications of using the IMPLICIT NONE statement.
  • One participant identifies an error related to the undeclared variable "i" in the DO loop statement.
  • Another participant suggests removing the IMPLICIT NONE statement, implying it may not be necessary for compilation.
  • In contrast, a different participant argues against removing the IMPLICIT NONE statement, stating that it enforces explicit variable declarations and prevents potential issues with undeclared variables.
  • Further, a participant elaborates on the risks of not using IMPLICIT NONE, explaining that it can lead to the creation of unintended variables, resulting in incorrect program behavior or runtime errors.
There is disagreement regarding the necessity of the IMPLICIT NONE statement, with some participants advocating for its removal while others strongly oppose this action, emphasizing its importance for proper variable management.
The discussion highlights the importance of variable declarations in Fortran and the potential pitfalls of compiler behavior when IMPLICIT NONE is omitted. There are unresolved assumptions about the necessity of certain coding practices in Fortran.
zandria
I am working with visual Fortran (f90 I believe)
I have the following program and it says that I have 2 errors. I have narrowed it down to having something to do with my loop statement in bold. Is there something wrong that I'm not getting?
program exercise1
implicit none
integer :: limit, f1, f2, f3
read*, limit
f1 = 1
if (limit >= 1) then
print*, f1
end if
f2 = 1
if (limit >= 2) print*, f2
do i= 3, limit
f3 = f1 + f2
print*, f3
f1 = f2
f2 = f3
end do
end program exercise1
Technology news on Phys.org
nevermind, figured it out. I did not define "i" as a variable in my list of integers
Remove (delete) the statement: implicit none
DO NOT REMOVE THE IMPLICIT NONE STATEMENT
Having that in forces the user to explicitly define their variables. Removing that statement to get a program to compile will nearly always cause problems later down the line.
Simply put: fix it right the first time.
Without the IMPLICIT NONE, if you mis-spell the name of a variable once, the compiler doesn't catch it for you, as an undeclared variable. Instead, it cheerfully allocates a new variable with that name, which has no connection with the variable you meant to use. Your program compiles "successfully," but when you run it, it either produces incorrect results or crashes with a run-time error that can be very difficult to track down.
  • · Replies 17 ·
  • · Replies 20 ·
