Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image How can compretion be possible??? Share It Thread Tools Search this Thread image
Old Jun3-09, 07:36 PM                  #1
prysdieheer
prysdieheer is Offline:
Since a 64bit integer can store 2^64 possible combinations and a 63bit integer can store 2^63 possible combinations and 64<63, how is it possible to compress anything?
In love
Prys die Heer!
Old Jun3-09, 08:01 PM                  #2
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
PF Contributor PF Contributor
Re: How can compretion be possible???
In love
Prys die Heer!
Every compression algorithm actually increases the size of many inputs. They are useful because they decrease the size of the ones you are most likely to be using.
Old Jun3-09, 08:22 PM                  #3
prysdieheer
Thank You Sylas, that is a very good answer, really helps me.
But I have one more question, do you think it is possible to compress things over and over again, because I think I know an algorithm that can( It also makes a very good sorting algorithm)
In Love
Ashton
Old Jun3-09, 09:16 PM                  #4
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
In Love
Ashton
If is a formal mathematical proof that there is no algorithm which compresses over and over again indefinitely. A good algorithm will normally (that is, on the inputs of interest) return a string that cannot be compressed a second time. If you have an algorithm that often compresses its input a second time, then the algorithm is not a good one for that class of inputs.
Old Jun3-09, 10:07 PM                  #5
mgb_phys
Physics Guru 2008
mgb_phys is Offline:
Recognitions:
Homework Helper Homework Helper
I have an excellent algorithm that compresses any input into a single bit.
Unfortunately I haven't written the decompression algorithm yet.
Old Jun4-09, 12:49 AM                  #6
AUMathTutor
AUMathTutor is Offline:
"I have an excellent algorithm that compresses any input into a single bit.
Unfortunately I haven't written the decompression algorithm yet."
I love you.
Old Jun4-09, 12:52 AM                  #7
AUMathTutor
To the OP:
The theory of compression is basically that, even though 2^64 different values are possible, in practice you use many fewer than these. If you're writing a letter in English, you probably use ~ 100 characters, tops. Also, some values occur more frequently than others. Using this information, you can replace frequently occuring characters with longer bit strings and vice versa, so it all works out in the end.
Old Jun4-09, 01:05 AM                  #8
junglebeast
junglebeast is Offline:
In love
Prys die Heer!
Some examples:
Instead of sending a document as letters, you can replace each word with a single number and use a lookup table to reconstruct the message along with a dictionary.
What if I want to send the string "00101011". This has 8 numbers, each number represented by a byte. But since I only used 2 different possible numbers, it could all be encoded as bits in a single byte.
What if I want to send "5555555566666666666" I could send that as 19 numbers, or I could send "8.5.11.6" which represents 8 fives followed by 11 sixes.
An audio file is a sequence of numbers representing the magnitude of the combined waveform at each instant in time. If it remains a constant pitch, then this will look like a sine wave. If you just send the parameters of the sine wave, you don't need to send an infinite number of magnitude measurements.. a music file can be compressed by extracting a bunch of waves which, when added together, recreate the original music. The same thing is done in JPEG images, but with colors.
Compression uses these sorts of tactics
Old Jun4-09, 01:30 AM                  #9
sylas
sylas's Avatar
sylas is Offline:
Recognitions:
I have an excellent algorithm that compresses any input to half its size. I wrote it on the margin of a book somewhere. Unfortunately, I have compressed all my books, and now the margins look like everything else, and I can't find the algorithm again.
Old Jun7-09, 11:58 PM                  #10
granpa
granpa is Offline:
http://en.wikipedia.org/wiki/Arithmetic_coding
Old Jun8-09, 05:13 AM                  #11
Jeff Reid
Jeff Reid is Offline:
Originally Posted by sylas View Post
There is no algorithm which compresses over and over again indefinitely.
Perhaps he meant an algorithm that iterates thorugh various schemes to find an optimal compressed encoding of data. pkzip and later compression algortihms do this, such as a check to see if huffman encoding of 8 bit values (bytes) is beneficial (text files are good for this scheme), in addition to choosing a huffman encoding table for lengths and offsets using a moving window (LZ1 like) compression algorithm.
image image
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
