What is the Solution to a Problem on Energy Transfer Using Trigonometry?
The discussion revolves around a physics problem involving energy transfer and trigonometry, specifically focusing on a body swinging in a vertical plane and its interactions with another body during a collision.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants suggest determining the height of the body from the bottom position and calculating potential energy. They mention applying conservation of energy and momentum principles but express uncertainty about how to begin the problem.
Some participants have offered steps to approach the problem, including calculating potential energy and applying conservation laws. However, there is a lack of explicit consensus on the best method to tackle the problem, and some participants are still seeking clarification on how to proceed.
The original poster indicates a lack of understanding of the problem setup and expresses a need for guidance. The problem involves specific parameters such as mass, length of the cord, and angles, which may influence the discussion.
taichi2910
1. A Body Aof 5kg is attached to the end of a light supension cord 2m long and is free to swing in a cirular path in a vertical plane . the body A is drawn aside and the suspension cord is held taut at an angle of 30 below the horizontal .
a. determine the linear velocity of the weight when passing through the bottom position
b. at the instant of reaching the bottom position, body A collides with body B of mass 10kg moving horizontally with a velocity of 2m/s in the same vertical plane as, but in the opposite sense to Body A.
if after impact on body A rebounds to height of 0.3m above it bottom postion determine the velocity of B immediately after impact.
c. calculate the loss of energy at impact
I must confess i have got no clue on how to tackle the problem, and as such i don't know where to start on, so please i would really appreciate any help and explanation offered to me .
thanks in advance.
1) Determine the height of the body from the bottom position.
2) Calculate the potential energy at that position.
3) Apply the conservation of energy to find the velocity at the bottom position.
4) For part b, apply the conservation of momentum.
thank you for you respond, but please rl.bhat can you tell wat to used to tackle the explanation, am absolutely clueless.
Length of the string is given. Angle below the horizontal is given. Draw the figure. Using trig. find the height of the body from the bottom position.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 38 ·
