Tchebysheff proof, help understanding transition to last step |
Jun4-09, 12:09 PM
#1
el_llavero is
Offline:
proof attached as pdf in link provided
Jun4-09, 02:12 PM
#2
EnumaElish is
Offline:
Recognitions:
Re: Tchebysheff proof, help understanding transition to last step
Using A for |A| and kk for k squared:
1 > Akk/n
1 < n/(Akk)
A < n/kk
A/n < 1/kk
1 - A/n > 1 - 1/kk
So the stated result actually holds with strict equality.
Jun4-09, 02:15 PM
#3
el_llavero is
Offline:
I actually got some help with the algebraic manipulation, which was clouding my conceptual understanding, after looking at this more I realized what it all meant and why the use of >= instead of > at the end
Divide by k^2 results in 1/(k^2)>|A|/n
multiply both sides by -1 (fips inequality) and add 1 to both sides results in 1- 1/k^2 < 1-|A|/n
change from strict inequality to weak inequality to account for proportion of all elements "~A" INTERSECTION "B" results in
1- 1/k^2 <= 1-|A|/n
Jun4-09, 02:23 PM
#4
el_llavero is
Offline:
1 > Akk/n
1 < n/(Akk)
A < n/kk
A/n < 1/kk
1 - A/n > 1 - 1/kk
But the only way 1 - A/n > 1 - 1/kk describes the proportion of measurements in B, i.e. ~A, is to switch to weak inequalitysince strict inquality leaves out part of B, t/f weak inequality is required.
What do you think?
Jun4-09, 05:13 PM
#5
EnumaElish is
Offline:
Recognitions:
|A| is a real number, like 2.
If 2/n < 1/kk then 1 - 2/n > 1 - 1/kk. Not so?
Jun4-09, 05:39 PM
#6
el_llavero is
Offline:
the cardinality of A, i.e. |A|, is a natural number, an integer in the set {0,1,2,3,...}
if |A|=1, and k =1 and n = 1 then the equations are equal. thats assuming that there is no restriction on n being equal to 1 and card(A) being equal to 1.
Jun4-09, 06:03 PM
#7
EnumaElish is
Offline:
Recognitions:
Of course, if the premise were 2/n < 1/kk then 1 - 2/n > 1 - 1/kk would be the case. But the premise is stated with strict inequality.
Jun4-09, 06:21 PM
#8
el_llavero is
Offline:
yes you're right. So the use of weak inequality may have something to do with describing the complement of A?
Jun4-09, 06:56 PM
#9
EnumaElish is
Offline:
Recognitions:
Or what they meant was 2/(n-1) < 1/kk, then they replaced n-1 with n but forgot to change < to <.
Jun5-09, 08:53 AM
#10
el_llavero is
Offline:
Perhaps that's the case, because the strict inequality was used to derive the last line. Moreover, perhaps my set element argument was more of a way to try and rationalize the use of the weak inequality. I'm going to try and get a response from the author of this proof, and see what he says. Thanks for your responses EnumaElish.
Jun6-09, 09:17 AM
#11
el_llavero is
Offline:
I corresponded with a professor from a previous class about this and he reminded me about the use of logic in proofs
If you assume p is true then you may also conclude that ( p OR q) is true, no matter what q is! q doesn't ever have to be true since we've assumed p is. It's a fact in logic referred to as (addition or generalization).
p is LHS > RHS, and q is LHS = RHS.
Jun6-09, 06:11 PM
#12
EnumaElish is
Offline:
Recognitions:
I am not saying the proof is wrong; I am saying it can be more definitive.
