How to Calculate Equivalent Torque Distance on a Pivoting Rod?
  • Thread starter Thread starter PrideofPhilly
    Torque
The discussion focuses on calculating the equivalent torque distance on a pivoting rod when a force F is applied at an angle theta. The torque (t) is defined by the equation t = rF, where r is the distance from the pivot to the point of force application. The participant proposes that the equivalent distance (d) for the same torque is given by d = Lsin(theta), which is accurate when considering the force applied horizontally. The conclusion emphasizes that at a 90-degree angle, the force is fully effective in generating torque.
  • Understanding of torque and its calculation using the formula t = rF
  • Knowledge of trigonometric functions, specifically sine
  • Familiarity with the concept of pivoting rods in physics
  • Basic principles of rotational motion
  • Study the implications of torque in rotational dynamics
  • Explore the application of trigonometric functions in physics problems
  • Investigate the effects of varying angles on torque generation
  • Learn about frictionless pivot systems and their characteristics
Physics students, mechanical engineers, and anyone studying rotational dynamics and torque calculations.
PrideofPhilly
A rod can pivot at one end and is free to rotate without friction about a vertical axis. A force F is applied at the other end, at an angle theta to the rod. If F were to be applied perpendicular to the rod, at what distance d from the axis of rotation should it be applied in order to produce the same torque t?
t = rF
My answer: d = Lsin(theta).
Is that correct or am I missing something?
If the force is applied horizontally this would be true.
When the angle is 90 degrees the force would be fully engaged in developing torque at that displacement.
