Is the speed of light a velocity or acceleration?
The discussion revolves around the nature of the speed of light, specifically whether it should be classified as a velocity or an acceleration. Participants explore concepts related to massless particles, the implications of reaching light speed, and the relationship between speed and acceleration in the context of physics.
  • Some participants suggest that since light speed requires an infinite amount of time to achieve, it could be considered an acceleration.
  • Others argue that light speed is a velocity, as it indicates the distance traveled by a photon and does not involve acceleration.
  • A distinction is made between massless particles, which always travel at the speed of light and do not accelerate, and massive particles, which cannot reach light speed and would require infinite acceleration to do so.
  • Some contributions clarify that acceleration is defined as the change in velocity over time, and thus cannot be equated with speed.
  • There are discussions about the electromagnetic spectrum, noting that while all electromagnetic waves travel at speed c in a vacuum, their frequencies and wavelengths vary.
  • One participant introduces the concept of rapidity, suggesting it provides a different perspective on motion in relativity, where the rapidity of light is infinite.
  • Another participant reflects on their initial confusion regarding the relationship between velocity and acceleration, later retracting their question after further consideration.
  • Some participants discuss the implications of mass gain for massive particles as they approach light speed, likening it to a form of resistance to acceleration.
Participants express multiple competing views on whether the speed of light should be classified as a velocity or an acceleration. The discussion remains unresolved, with differing interpretations and clarifications provided by various participants.
Some statements rely on specific definitions and assumptions about mass, velocity, and acceleration, which may not be universally accepted. The discussion includes unresolved mathematical and conceptual nuances regarding the nature of light and motion.
ryuunoseika
Since light speed requires an infinite amount of time to achieve it's effectively an acceleration right? Does anyone know what I'm trying to say? And better yet, if it's right?
1. Acceleration is the derivative of velocity wrt time.
2. A massless thing can accelerate to c in zero time.
A massless thing always travels at c so it never really accelerates.
You answered your question right there. The speed of light is a speed/velocity. It indicates the distance traveled by a photon.
Remember, that c is the distance traveled by a photon in vaccuum. Light and other electromagnetic radiation will have different speed in different matters.
Cheers
A massive particle can never achieve the speed of light, so if it tries to, it will accelerate forever.
A massless particle travels at the speed of light, never accelerating or decelerating.
speed has the units of velocity so it is clearly a velocity.
Hi there,
Not really. Since the accelaration is define as [tex]\frac{dv}{dt}[/tex], if the speed of the particle/object stops increasing, its acceleration follows with.
I agree that to accelerate a massive object that is close to the speed of light is very hard. But this is due to the increase in mass: [tex]F = \frac{dp}{dt} = \frac{d(mv)}{dt}[/tex]. This is the reason why a massive object cannot reach the speed of light.
Cheers
wrong.
Nvm, no one understands what I am saying. I didnt really phrase it right.
Hi ryuunoseika! :smile:
Yes, if you try to accelerate up to the speed of light, however long you take, you will never quite reach the speed of light …
so in that sense light speed does require an infinite amount of time to achieve.
But it's not an acceleration …
it doesn't move away as you're trying to catch it! :wink:
ryuu...
mejen posted one view for massless particles; tiny-tim the other side for particles with mass...in any case your statement which I quoted implied equating velocity and
acceleration...that can't be done, it's just never true...acceleration is the rate of change of velocity...they measure two different, but related, variables...
I found this quite baffling. After all, speed is measured in m/s and acceleration in m/s2, so how can a speed be an acceleration?
But then tiny-tim said this:
Then I realized what you were thinking.
If you are accelerating, trying to catch up with a photon, you find that the speed of the photon is still c. From your point of view, it appears that the photon is accelerating as you accelerate, so that the difference in speeds remains constant.
But this is an illusion, based on the assumption that it is valid to subtract speeds.
You actually need to use the formula
[tex]\frac{u - v}{1 - uv/c^2}[/tex]​
There is another way to measure motion in relativity, and that is "rapidity".
The relationship between speed v and rapidity ϕ (measured in the same units as speed) is given by the equation
[tex]\frac {v}{c} = \tanh \frac{\phi}{c} = \frac {e^{\phi/c} - e^{\phi/c}} {e^{\phi/c} + e^{\phi/c}}[/tex]​
That may look complicated, but rapidity has lots of nice properties compared with speed.
  1. For objects all moving in the same straight line, rapidities can be added and subtracted.
  2. The rapidity of light is infinite.
  3. At low speeds, rapidity and speed are approximately the same.
  4. For an object undergoing constant proper acceleration α (as measured by its own accelerometer), rapidity increases linearly with proper time τ (as measured by its own clock), ϕ = ατ
Looked at from this point of view, the rapidity of light isn't an acceleration, it's just infinite so no wonder you can't reach it.
Technical note: I've deliberately chosen to define rapidity with the dimensions of speed, but many authors define it dimensionlessly via [itex]v = c \tanh \phi[/itex]
No, no, i understand that acceleration is a term for change in velocity over change in time, and that velocity is merely the derivative of an acceleration function. All i did was poorly phrase my question; i was very tired when i posted it and, admittedly, not of sound mind.
I was think in terms of velocity and acceleration which was counter-compensated for the lorentz transformation (i.e. The speed of light is infinity) to describe velocity from the perspective of the accelerating body. Its an absurd way of looking at things and it produces unreasonable results. I have no idea why i was using it, and I withdraw my question as i later answered it on my own.
this is not true: consider the electromagnetic spectrum. all of these waves are exactly the same, at least in what you might consider to be the wave 'quality.' the only thing that changes proportionately is their frequency and wavelength. light makes up a very small part of this spectrum falling under the visible light category. just because radio waves for example are massless, this does not mean that they move anywhere near the speed of light. especially because even looking at different colors of light, they all have different wavelengths and thus move slightly faster or slower than one another.
Welcome to PF!
Hi dsmith23! Welcome to PF! :smile:
dsmith23 said:
… just because radio waves for example are massless, this does not mean that they move anywhere near the speed of light. especially because even looking at different colors of light, they all have different wavelengths and thus move slightly faster or slower than one another.
Yes, that's true in a material (air, glass, etc), but not in a vacuum
in a vacuum, all colours, and radio waves etc, go at the same speed (c). :wink:
All electromagnetic waves travel in vacuum at the same speed c. The wavelengths λ and frequencies f all vary, but the speed remains constant.
[tex]c = f \lambda[/tex]​
I second that!
I like to think that the mass gained by an object as it approaches the speed of light is basically a resistance to it's acceleration. So maybe massive particles can travel at the speed light, the problem is accelerating to such a speed.
isn't this the same as the resistance of a massive particle to accelerate in space time at low velocities, except, at high speed the resistance is plotted on an expotantial curve rather than a linear one?
Hi there,
What you are describing here is the definition of inertia, and not the increase of mass at very high speed.
And who is talking about exponential instead of linear. If you look at the mass increase of an object, you will see that the exponent never appears into it, but rather a square.
Cheers
  • · Replies 51 ·
  • · Replies 93 ·
  • · Replies 45 ·
  • · Replies 25 ·
  • · Replies 130 ·
18K
  • · Replies 18 ·
  • · Replies 74 ·
  • · Replies 21 ·
  • · Replies 47 ·
