Hamiltonian is commutable with momentum operator
The discussion centers on the commutation relationship between the Hamiltonian and momentum operator in the context of a one-dimensional potential well. Participants explore the implications of this relationship for energy eigenstates and momentum eigenstates, particularly in finite and infinite potential wells.
  • Some participants assert that the Hamiltonian commutes with the momentum operator, while others argue that this is not the case in a one-dimensional finite well.
  • One participant notes that momentum eigenstates in a potential well are not simple complex exponentials and involve integration over all space, challenging the assumption that the particle behaves like a free particle.
  • Another participant questions the existence of momentum eigenstates in an infinite well, suggesting that boundary conditions prevent these states from fitting within the potential constraints.
  • It is proposed that for a free particle, the Hamiltonian depends solely on momentum, allowing for commutation, whereas for a particle in a well, the Hamiltonian includes position dependence, leading to non-commutation.
  • Concerns are raised about the implications of boundary conditions on the eigenfunctions of momentum, with some participants indicating that these conditions result in a lack of valid momentum eigenstates.
Participants express differing views on whether the Hamiltonian commutes with the momentum operator in one-dimensional potential wells, with no consensus reached on the existence of momentum eigenstates in these contexts.
Limitations include the dependence on the specific form of the potential and the boundary conditions applied, which influence the validity of the arguments regarding commutation and the existence of eigenstates.
eigenpost53
[H,P]=0 , where P is momentum operator.
Hamiltonian is commutable with momentum operator. so H and p have
wave function simultaniously, but in 1-dimensional potential well degeneracy
not exist.
what is the reason?
Not so, e^{ip} and e^{-ip} have opposite momenta, but the same energy.
A particle in a well is not a free particle. The momentum eigenstates are not simple compex exponentials. Basically, a momentum eigenstate involves an integration over all space. Just because the particle has a zero probability of being outside the well does not allow you to ignore the well when considering the momentum eigenstates (otherwise, you would get a wavefunction that says the particle can be outside the well, i.e. periodic B.C.s).
As far as I remember, momentum only commutes with the Hamiltonian for a free particle Hamiltonian (or in a configuration space orthogonal to all of the constraint degrees of freedom).
thanks for your answer,but i don't get it well
Is the Hamiltonian commutable with momentum operator in the 1- dimensional finite well?
can you see [p^2/2m +v , P]=0 is to formed, for V=constant?
why in this case, we can't find degeneracy?
why eigenstate of momenta are not exsist when it is 1-dimensional infinite well?
wave fuction of momenta which we could get through Fourier transform for eigenfuntion of energy
can not to be satify by wave funtion should be 0 in between potential boundary
therefore si(0)=psi(L)=0 are not possible.
we can know that though we solve making a eigenvalue eqeution of momenta, that is not satisfied with B.C.s
How do I understand this?
I will appologize in advance for possibly not knowing what you are asking. Let me try this, though:
For a 1-D single particle, consider H = f(X,P). That is to say, the Hamiltonian is formed by combining the position and momentum operators in some way.
For a free particle, H = g(P). That is to say, the Hamiltonian does not depend on X, only on P. Now, P commutes with itself, so P commutes with g(P), and, therefore, [P,H] = [P,g(P)] = 0 for a free particle.
For a particle in a well, you have H = g(P) + V(X). That is to say, the Hamiltonian depends on both X and P. Now, P does not commute with X, so P does not commute with V(X), and, therefore, [P,H] = [P,(g(P) + V(X))] = [P,g(P)] + [P,V(X)] = 0 + [P,V(X)] /= 0.
Something I just noticed after rereading your post:
I think you may be biasing yourself to the x-basis. Don't think of this in terms of a basis, think of it in terms of the entire space. If you just limit yourself to the range of x-values inside the well, that is like limiting yourself to consider only certain components of a vector when you consider the eigenvalue problem. This is a bad thing to do because, when you consider the same eigenvalue problem in a generally different basis, those particular components no longer have any meaning.
No.
____________________
V is not a constant. It is a pair of "step" functions. V changes at the boundaries of the well.
Since P is like -id/dx,
[P,V] = a pair of Dirac delta-functions ,
which is certainly not zero.
In this unphysical (because, V = infinity in some regions of space) "simplification" (which in some cases can be a good approximation), the "price" that we must "pay" is that the eigenfunctions of P just don't "fit into the picture".
This makes perfect "physical" sense. Since an eigenfunction of P is just a free particle moving to the left or moving to the right, those eigenfunctions will not "fit into a picture" which forbids the wavefunctions from being anything but zero outside of the interval (a,b).
  • · Replies 31 ·
  • · Replies 32 ·
  • · Replies 21 ·
