Thread Closed
Is there exist a shortest closed curve in the homology class of a simple closed curve
Share Thread Thread Tools
Jun5-09, 08:50 PM   #1
I am seeking the answer to the following question: Given a simple closed curve on a compact Riemannian surface(a compact surface with a Riemannian metric), whether there exists, in the homology class of this simple closed curve, a (single) closed curve which has the shortest length measured with respect to the given Riemannian metric? In other words, whether there exists a shortest path which is composed by a single closed curve in the homology class of a given simple closed curve? I think this might be interesting, can you help me?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Jun7-09, 04:10 AM   #2
Recognitions:
Homework Helper Homework Help
"Let M be a compact Riemannian manifold. [...] Likewise, every homotopy class of closed curves in M contains a curve which is shortest and geodesic."
That's theorem 1.5.1 from this book. Also the proof is given there (and luckily for you, within the previewable pages). Actually I suspect (I didn't look at it nor try it) that it's not very hard so maybe you want to try it yourself first.
Jun7-09, 07:48 AM   #3
Well, The question I posted is still unsolved.
first, thank CompuChip. But what I am asking is the existence of the geodesic in the "homology" class of a given simple closed curve, rather than the existence of the geodesic in the "homotopy" class of a simple closed curve. Can you help? Thanks a lot for your prospective help.
Jun11-09, 08:44 AM   #4
can anyone help?
Jun14-09, 06:26 AM   #5
Not sure of the proof but I would try covering the curve with open balls then deforming it to a geodesic segment in each ball. This would give you a piece wise smooth geodesic in the same homotopy class. It will locally minimize length but maybe not globally. You can then try to show that by smoothing out the kinks you get a geodesic that is even shorter.
This argument should work but as is begs the question because there still may be even a shorter curve that is not a geodesic.
So maybe you start out with a length minimizing curve in the same homotopy class. If it is not a geodesic apply this procedure of geodesic approximation to get even a shorter curve.
Details to be worked out.
Jun14-09, 06:37 AM   #6
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by hyperttt View Post
Surely knowing something about the homotopy class tells you something about the homology class?
Thread Closed
Tags
homology class, riemannian metric, shortest, simple closed curve
Thread Tools
Similar Threads for: Is there exist a shortest closed curve in the homology class of a simple closed curve
Thread Forum Replies
How does an electron behave in a closed time like curve? Beyond the Standard Model 6
Closed curve on R^3 Calculus & Beyond Homework 5
Simple closed curve area? Calculus 6
complex analysis - area inside a simple closed curve Calculus 1
