Magnetic and electric field between current carrying coaxial cables
The discussion centers on calculating the velocity of an electron moving between two long concentric cylindrical conductors with a potential difference V and carrying equal but opposite currents I. The magnetic field B is derived using Ampere's Law as B = μ₀I / (2πr) for the region between the cylinders. The electric field E is determined from the capacitance formula C = 2πε₀ / logₑ(b/a) and is expressed as E = V / (r logₑ(b/a)). The final expression for the electron's velocity is |u| = (2πV) / (μ₀I logₑ(b/a)), confirming that the potential difference can be treated as a separate electric field along the radial direction.
  • Understanding of Ampere's Law and its application in cylindrical coordinates.
  • Familiarity with electrostatics and the concept of electric fields between concentric cylinders.
  • Knowledge of capacitance calculations for cylindrical conductors.
  • Basic principles of electromagnetism, including the Lorentz force equation.
  • Study the derivation of electric fields in cylindrical geometries using Gauss's Law.
  • Explore the implications of the Lorentz force on charged particles in magnetic and electric fields.
  • Investigate the relationship between current, voltage, and magnetic fields in coaxial cables.
  • Learn about the practical applications of coaxial cables in electrical engineering and telecommunications.
Students and professionals in physics and electrical engineering, particularly those focusing on electromagnetism, circuit design, and the behavior of charged particles in fields.
disillusion
Two long concentric, cylindrical conductors of radii a and b (a<b), are maintained with a potential difference V and carry equal but opposite currents I.
An electron, with velocity u parallel to the axis, enters the evacuated region between the conductors and travels undeviated. Find an expression for |u|.
I am not sure I understood the question very well and would like to see what others make of the question.
Since the current is flowing so there would be an E field along the direction of the current, which would not affect the electron. Should I just treat the potential difference as a separate E field along the radial direction?
[tex]\oint_{C} \textbf{B}\cdot \textbf{dl}=\mu_{0}\int di[/tex]
[tex]\oint_{S} \textbf{E}\cdot \textbf{dA} = \frac{Q}{\epsilon_{0}}[/tex]
[tex]\textbf{F}=q(\textbf{E} +\textbf{u}\times \textbf{B})[/tex]
The B field is curling around the inner cylinder.
Using Ampere's Law,
[tex]B=\frac{\mu_{0}I}{2\pi r}[/tex]
for a<r<b
r = distance from centres of cylinders
E field (electrostatics) of concentric cylinders
[tex]E=\frac{Q}{2\pi\epsilon_{0}r}[/tex]
where Q is charge per unit length, assuming length>>r
Following from above
Capacitance
[tex]C=\frac{2\pi\epsilon_{0}}{log_{e}(\frac{b}{a})}[/tex] per unit length
so using Q=CV, get
[tex]E=\frac{V}{r log_{e}(\frac{b}{a})}[/tex]
now force F=q(E+u^B)
so
[tex]|\textbf{u}|=\frac{|\textbf{E}|}{|\textbf{B}|}[/tex]
and so
[tex]|\textbf{u}|=\frac{2\pi V}{\mu_{0}I log_{e}(\frac{b}{a})}[/tex]
would this look right?
I would think so.
The result looks OK.
  • · Replies 16 ·
  • · Replies 26 ·
