Can anybody differentiate this to simplest formy=4/3+5cosx
  • Thread starter Thread starter lakshmi
    Differentiate
The discussion revolves around differentiating the function y = 4/3 + 5cos(x). Participants are exploring the differentiation of trigonometric functions and the application of rules such as the product and quotient rules.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Some participants suggest trying differentiation independently and question the original poster's specific difficulties. Others inquire about the derivative of constants and the function cos(x). There is mention of the product rule and its applicability, as well as a discussion about the correct interpretation of the function's form. Additionally, a participant raises a limit problem involving differentiation and L'Hospital's rule.
The conversation is active, with multiple interpretations of the function being discussed. Some participants provide guidance on differentiation techniques, while others express uncertainty about the correct form of the function. There is no explicit consensus on the interpretation of the original problem.
Participants note the potential confusion regarding the function's expression, whether it is y = 4/3 + 5cos(x) or y = 4/(3 + 5cos(x)). There is also mention of the original poster's lack of experience with differentiation and trigonometric functions.
lakshmi
can anybody differentiate this to simplest form
y=4/3+5cosx
What about trying it out yourself?
What is your specific problem with this?
Do you know the derivative of a constant?
Do you know the derivative of cos(x)?
for 5cos(x) product rule may be useful
By the way, is that (4/3)+ 5cos(x) or 4/(3+5cos(x))?
nix: The product rule does not need to be applied as the 5 looks to be independent of x.
Hello,
I have a limit to solve which in fact involves differentation (L'Hospital's rule)
Lim as x->inf. (xe^[1/x]-x)
I solved it but I am not quite sure. It can't be solved immediately by substitution because it becomes an undet. form. So applying the Hospital Rule I found Lim as x->inf (e^[1/x] - [(e^{1/x})/x] - 1)
Then it gives e^0 -0-1 = 1-1=0
I don't know now if it's correct because I don't even have a TI calc. to check the answer.
Thanx
Your answering a question that is a month old and that isn't the correct solution either.
[tex] y=\frac{4}{3+5\cos{x}}[/tex]
You can use the quotient rule or change the denomenator to a negative power
Quotient rule:
given a function f(x)
[tex] f(x)=\frac{g(x)}{h(x)}[/tex]
Then the quotient rule would be:
[tex] f^\prime (x)=\frac{h(x)g^\prime (x)-h^\prime (x)g(x)}{(h(x))^2}[/tex]
if we let the numerator be g(x) and the denomenator be h(x) we get:
[tex] g(x)=4[/tex]
[tex] g^\prime (x)=0[/tex]
[tex] h(x)=3+5\cos{x}[/tex]
[tex] h^\prime (x)=-5\sin{x}[/tex]
Plugging the individual functions into the quotient rule yields:
[tex] f^\prime (x)=\frac{(3+5\cos{x})(0)-(-5\sin{x})(4)}{(3+5\cos{x})^2}[/tex]
simplify:
[tex] f^\prime (x)=\frac{20\sin{x}}{(3+5\cos{x})^2}[/tex]
If you look at the problem as:
[tex] y=\frac{4}{3}+5\cos{x}[/tex]
you get:
[tex] y^\prime=-5\sin{x}[/tex]
[edit]transposed 3 and 4...fixed
[tex]y= \frac{4}{3+5cos x}[/tex]
How did you decide that that was the problem? I would think that y= 4/3+ 5 cos x would be more reasonably interpreted as y= (4/3)+ 5 cos x. I asked lakshmi earlier which was intended and got no answer.
I answered both possible forms of the question.
[edit]Also, KnowledgeIsPower you have a misconception about the generel form. the derivative [itex]x^n[/itex] only applies to [itex]x^n[/itex]. You can't apply this to the transcendental functions because each has its own rule. For example: the derivative [itex]\ln x[/itex] is not [itex]1/\ln x[/itex] as [itex]x^n[/itex] would suggest.
[edit][edit] The response I was addressing seems to have disappeared anyway.
Ok thanks for the information. I just studied a number of new trig content and thought i'd jump right in - though i hadn't done differentiation/integration on trigonomic functions.
My mistake, sorry.
But what prevents you from just classing sinx as 'y' and differentiating that way?
You can say y=sin x but you have to use the chain rule to get dy/dx.
Here, given: y=sin x and you want to find dy/dx.
let A=sin x
y=A
dy=dA
dy/dA=1
Well that's not what we wnat we are trying to find dy/dx
[tex] \frac{dy}{dx}=\frac{dy}{dA}\frac{dA}{dx}[/tex]
The above works just like algebra. The dA's will cancel to give dy/dx; however, you must find dA/dx to use the chain rule.
A=sin x
dA=cos xdx
dA/dx=cos x
thus dy/dx=(1)(cos x)
or dy/dx=cos x
back to the original problem: y=sin x
You'll learn this soon enough, but the derivative of sin x is cos x so and the derivative of cos x is -sin x.
thus if we find the derivative of y=sin x we get dy/dx=cos x
I'd liken the process to fractional addition. You can't simply add 1/3 and 1/2 together. You have to first find a common denominator. Here too we can't simply say sin x=A and get the same result as y=sin x. We still need to do the intermediate steps to convert dA/dx and dy/dA to dy/dx.
You'll soon learn that there are 20 to 30 common derivatives you'll need to memorize.
Hope this helped.
Thanks a lot for the explanation. That was very interesting and informative. Fools rush in..., guess i shouldn't jump ahead.
It's amazing that you people will help those less knowledgeable out for free. It's a pity there's no way to return the favour.
Thanks again.
