Chemical effect of electric current
The discussion revolves around the chemical effect of electric current on a copper sulfate solution, specifically focusing on the ionization process and the behavior of ions at the electrodes during electrolysis.
  • Exploratory, Conceptual clarification
  • Participants explore the ionization of copper sulfate and the movement of ions towards the electrodes. Questions arise regarding the specific roles of copper and sulfate ions during the process.
Some participants have provided insights into the behavior of ions in the solution and the charging of electrodes, while others seek clarification on specific aspects of the process. Multiple interpretations of the expected depth of explanation are being considered.
There is a suggestion that the original poster may need to align their explanation with textbook descriptions, indicating potential constraints on the depth of analysis expected.
lakshmi
explain me about ionisation of copper sulphate solution when an electric current is passed through it
what do you specifically want to know about it?
Gza's point is that one can give a general description or a detailed analysis using properties of electrons or anywhere between. I suspect that in your case you are expected to give the description in your textbook just to prove you have read it!
chemical effect
i wanted to know how sulphate ion collets at anode and copper at cathode
Copper sulphate exists in aqueous solution as a bunch of ions swimming about in water. The ions are [tex]Cu^{2+}~~and ~~(SO_4)^{2-}[/tex]. When you dip a pair of electrodes in the solution and apply a potential (connect a battery) between them, you are essentially charging the electrodes. The cathode becomes negatively charged and the anode, positively charged. Hence the positively charged copper ions get attracted to the (negatively charge) cathode and the negatively charged sulphate ions get pulled towards the (positively charged) anode.
  • · Replies 44 ·
