Problem with polynomial division and 'i'
The discussion revolves around performing polynomial division involving complex numbers, specifically dividing the polynomial \(3x^2 + 2x + 7\) by the expression \((1+i)x - 2\). Participants explore various methods and approaches to tackle the division, including the use of complex conjugates.
  • One participant expresses difficulty with the polynomial division problem involving a complex number.
  • Another participant suggests treating \(i\) as a regular number and proposes starting the long division with \(\frac{3}{1+i}x\).
  • A different approach is introduced, where participants suggest multiplying the numerator and denominator by the complex conjugate \((1-i)x - 2\) to simplify the division.
  • Some participants discuss the results of their calculations, with one noting a remainder and questioning their approach.
  • Another participant clarifies the correct form of the denominator as \((1+i)x - 2\) and reiterates the use of the complex conjugate.
  • Further calculations are presented, showing how to multiply out the numerator and denominator after applying the complex conjugate.
  • One participant questions the utility of polynomial long division beyond finding leading-order behavior.
Participants express differing views on the best method to approach the polynomial division, with no consensus reached on a single correct method. Several methods are proposed, and some calculations are challenged or clarified, indicating ongoing uncertainty.
Participants rely on the properties of complex numbers and polynomial long division, but there are unresolved steps in the calculations and varying interpretations of the division process.
Slicktacker
I was learning polynomial division, and I can do most problems, except this one which is bothering me.
3x^2 + 2x + 7
(1+i)x - 2
How would I divide something like that? Nothing is working. Thanks.
Mathematics news on Phys.org
[tex]i[/tex] is just another number, no different from 12 or [tex]pi[/tex] or [tex]\sqrt{2}[/tex]... You'd perform the long division like you usually do. The first term in the quotient is [tex]\frac{3}{1 + i}x[/tex], maybe that can get you started.
Another way to handle fractions involving compex numbers is to "realize" the denominator. (I just made up that word!) Multiply both numerator and denominator by the complex conjugate of the denominator: the complex conjugate of (1+i)x - 2 is (1-i)x- 2 (negative i instead of positive i). Multiplying the denominator (and numerator) by that gives you a fraction in which the numerator is a real number.
You really want to mutiply through by the complex conjugate of 1+i tho'
edited to add Halls of Ivy beat me to it, again!
I tried the problem and I got
3x - 1 ... 3xi-i+6
------ remainder --------
1+ i ... (1+i)x-2
Anybody know where I'm going wrong?
What you want to do is mutply the top and bottom by he complex conjugate of 1 + i which is 1 - i to get:
[tex]\frac{(1-i)(3x^2 + 2x + 7)}{2x -4}[/tex]
I did that, and now I have a [tex]1-i[/tex] in the dividend, so how do I divide by that term using polynomial long division (should I multiply it by [tex]3x^2+2x+7[/tex] ?)
I get [tex]\frac{3}{2}x + 4 + \frac{23}{(2x-4)}[/tex], but where does the [tex]1-i[/tex] come in?
Is the denominator (1+i)(x-2) or (1+i)x-2 ?
The denominator is [tex](1+i)x-2[/tex]
[tex]\frac{3x^2+ 2x+ 7}{(1+i)x- 2}[/tex]
The denominator is (1+i)x- 2 and its complex conjugate is (1-i)x- 2 (just replace i by -i).
Multiply both numerator and denominator by (1-i)x- 2
The numerator will become (1-i)x(3x2+ 2x+ 7)- 2(3x2+ 2x+ 7)
= (3-3i)x3+ (2-2i)x2+ (7-7i)x- 6x2- 4x- 14
= (3-3i)x3+ (-4-2i)x2+(3- 7i)x- 14
The denominator will become (1-i)x(1+i)x-2(1+i)x-2(1-i)x+ 4
= 2x2- 4x+ 4 (No i !)
so the fraction is [tex]\frac{(3-3i)x^3+ (-4-2i)x^2+ (3-7i)x- 14}{2x^2- 4x- 4}[/tex]
Now use long division to reduce that.
Of what use is polynomial long division (other than to find the leading-order behavior of a rational polynomial)?
