What drives the magnetic field of Earth and how does gravity play a role?
The discussion revolves around the factors that drive the Earth's magnetic field and the potential effects of a hypothetical scenario where the planet "freezes." Participants explore the relationship between the Earth's core states, gravity, and the generation of the magnetic field, as well as the implications of the Earth's rotation.
  • Some participants suggest that if the molten core were to solidify, the magnetic field would significantly diminish or cease to exist.
  • Others clarify that if only the surface were to freeze, the magnetic field would remain unaffected.
  • There is a discussion about whether the Earth's rotation contributes to the magnetic field, with some proposing that the spinning of the solid core might generate a small magnetic field.
  • One participant questions the driving forces behind the dynamo process that generates the magnetic field and asks how gravity influences this model.
Participants express differing views on the implications of the Earth freezing and the role of gravity in the dynamo process. There is no consensus on how these factors interact or the extent of their effects on the magnetic field.
Some assumptions about the states of matter in the Earth's core and the definitions of "freezing" are not fully clarified, leading to potential misunderstandings in the discussion.
jontyjashan
What would happen to the magnetic field of Earth if the planet suddenly freezes?
Astronomy news on Phys.org
Um...the planet is pretty solid already. What do you mean by "suddenly freezes".
If the molten core were to become solid, I'd expect the magnetic field to be drastically smaller.
Not to be rude, and I'm glad you have an interest in the field of physics and astronomy, but you've posted an awful lot of weird topics on the matter.
Are you a physics student?
The magnetic field is generated by a dynamo process in the core. Liquid outer core + solid inner core + convection = magnetic field.
If by freezes you mean everything including the cores of the Earth become solid, then we won't have a magnetic field.
If you mean freeze by on the surface (crust) freezing, with snow and ice and what have you. Then nothing would happen.
Wouldnt the Earth spinning on its axis create a very small magnetic field because it is spinning the large solid core? I know if you turn the solid metal within an electric engine it creates a magnetic field similar to the one that creates its spin with electircity. Or is the spin of the Earth to slow to do something of that nature? Also i know if the Earth itself stopped spinning we would have no definite north and south fields on our planet
Indeed, the rotation of Earth also has it's fair share of duties for MF production
In the above model I don't see any driving force. Process- yes, state of matter- yes . How does gravity effect your model? And if you separate it out, How and why do you do it?
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 20 ·
