Ether |
Jun9-09, 07:22 AM
#1
joychandra is
Offline:
Ether
”According to the general theory of relativity space without ether is unthinkable; for in such space there not only wonld be no propagation of light, but also no possibility of existence for standards of space and time“..........this in an statement given by einstein.........please tell me what is the ether according to general relativity.
Jun9-09, 08:04 AM
#2
fatra2 is
Offline:
Re: Ether
Hi there,
From what I remember, Einstein had a hard time believing that light can travel in the empty space. Therefore, it was thought that their was an invisible material, without any mass, without any smell, without anything, that would allow light to travel through it.
Since then, many experiments were made to discover that ether, without success. The unsuccessful attempts to detect ether could be explain with some god d*** theory that was as complicated as it was ridiculous. Therefore, after a while, scientist decide to apply a simple procedure which says that if you have two theories that can explain the same thing, the simplest one is the most probable. Since then, the idea of ether has been dropped.
I hope I did not make any mistakes. This is what I rememebr from some class in University.
Cheers
Jun9-09, 08:38 AM
#3
turbo-1 is
Offline:
Re: Ether
If you will go to a library and check out Saunders and Brown's "The Philosophy of Vacuum", you will find that chapter 1 is a translation of Einstein's 1924 "On the Ether". He laid out his case in that writing more thoroughly than in his Leyden address. In essence, he claimed that "empty" space has properties that are modified by the presence of embedded matter. The idea was not well-accepted at the time, or presently.
Jun9-09, 08:38 AM
#4
ZikZak is
Offline:
Re: Ether
Einstein was not a god. We do not blindly follow anything and everything he had to say just because he said it. That is not the way things work in science. There is no ether in general relativity.
Jun9-09, 08:41 AM
#5
George Jones is
Offline:
Re: Ether
For any particular spacetime, there is a (tensor) field defined at each event (point) of spacetime that is used to tell whether paths in spacetime are timelike, lightlike, or spacelike. This field, known as the metric (tensor), seems to be what Einstein had in mind in the above.
Jun9-09, 08:47 AM
#6
fatra2 is
Offline:
Re: Ether
Hi there,
But very close to it. Let's say that he was one of the scientist that could explain very complex theories with little trains other simple objects. There has not been many like him (which I am thinking of Faraday as another one).
Cheers
Jun9-09, 09:38 AM
#7
ZikZak is
Offline:
Re: Ether
No.
He was a man, with all of the follies, foibles, and failures of that kind. We remember him for his truly inspirational achievements, but should also remember that he did not make them in a vacuum, and was wrong about many other things besides. To deify a scientist rather than appreciating the science is dangerous. It tends to lead people into exactly the OP's fallacy: argument from authority, which is the one thing, above all others, the process of science seeks to avoid.
Jun9-09, 10:02 AM
#8
fatra2 is
Offline:
Re: Ether
Not that many other.
He was certainly not a god, but let's give to Einstein what he deserve. He was an outstanding scientist, sometimes close enough to insanity, like others. Don't forget that the man brought into light some theories that are still completely misunderstood.
He was given a nobel price, but not for his special relativity, but for the brownien movement. I mean, the man was not only gifted in one field but in many.
Cheers
Jun9-09, 07:57 PM
#9
DaleSpam is
Online:
Recognitions:
Re: Ether
No, Einstein won the Nobel prize for his work on the photoelectric effect.
Jun9-09, 08:07 PM
#10
russ_watters is
Offline:
Re: Ether
Cheers
Your description of the history is incorrect: Einstein did not propose nor accept the classical version of the ether and, in fact, SR is (one of?) the first theory to discard the idea. What he proposed in the quote was something completely different. He's just saying that space still has properties, even if not the same properties previously believed.
Similar Threads for: Ether
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
The Ether
Pythagorean |
General Discussion |
17 |
Mar27-07 02:15 PM |
On ether
Oerg |
Special & General Relativity |
5 |
Jun1-05 11:08 PM |
Ether Ether everywhere.
saiarun |
General Physics |
1 |
Nov18-04 03:41 AM |
Looking for the Ether !!
Omni |
35 |
Sep20-04 09:29 AM |
Ether, plz help
xcube |
Chemistry |
5 |
Sep9-04 08:01 PM |
