Sum of (i^2)/(4^i) where i is from 0 to infinity.
  • Thread starter Thread starter Johnny Leong
    Infinity Sum
The discussion revolves around the infinite series sum of (i^2)/(4^i) where i ranges from 0 to infinity. Participants explore the convergence and bounds of this series, questioning the clarity of terms and the implications of approximations.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the bounds of the series, with some suggesting comparisons to simpler series for estimation. Questions arise regarding the clarity of terms like 0^2/4^0 and the nature of approximations in the context of series convergence.
The conversation is ongoing, with various interpretations of the series and its approximations being explored. Some participants have provided mathematical expressions and techniques for evaluating the series, while others express confusion and seek clarification on specific points.
There is a noted concern about the properties of the series terms and the validity of approximations used in the discussion. Participants are also navigating the implications of different approaches to the problem.
Johnny Leong
Please give me some hints:
You mean [tex]\sum_{i=1}^\infty \frac{i^2}{4^i}[/tex]? (I don't like [tex]\frac{0^2}{4^0}[/tex] - it's not necessarily clear what it is.)
Well, for [tex]i \geq 4[/tex] ,
[tex]2^i \geq i^2[/tex],
so
[tex]\frac{i^2}{4^i} < \frac{2^i}{4^i} = \frac{1}{2^i}[/tex]
so
[tex]\sum_{i=1}^\infty \frac{i^2}{4^i} < \frac{1}{4}+\frac{4}{16}+\frac{9}{64} + \sum_{i=4}^{\infty} \frac{1}{2^i}[/tex]
Perhaps you can find some better bounds?
I'm sorry, but what's unclear about 0^2/4^0?
[tex]\sum_{i=1}^\infty \frac{i^2}{4^i} > \frac{1}{4}+\frac{4}{16}+\frac{9}{64} + \sum_{i=4}^{\infty} \frac{1}{4^i}[/tex]
That gives a range of 0.7 to 0.9. Wonder if it isn't just 3/4 or 4/5 ?
Mathematica's saying 20/27 (~.740741). But, like most things Mathematica, I have no idea how it produced that number.
cookiemonster
Actually, this question could not give an accurate answer. The answer should just be an approximation, right? Because the terms in the summation are not having some sequence properties.
I think Gokul43201's answer would not be a good one because after I have read a book, I found that when we do some approximation, the approximation's value had better dominate the value of the original question.
What in the world does that mean? What do you mean by "dominate the value of the original question? An approximation is an approximation. There exist good approximations and bad approximations. The ideal is to get as close as possible to the true value for the work done.
[tex]F(x)=\sum_{i=0}^{\infty}i^{2}x^{i}[/tex]
[tex]\sum_{i=0}^{\infty}i^{2}x^{i}=\sum_{i=0}^{\infty}xi\frac{d}{dx}x^{i}[/tex]
[tex]\sum_{i=0}^{\infty}xi\frac{d}{dx}x^{i}=\frac{d}{dx}\sum_{i=0}^{\infty}ix^{i+1}-\sum_{i=0}^{\infty}ix^{i}[/tex]
[tex]\sum_{i=0}^{\infty}ix^{i}=x\frac{d}{dx}\sum_{i=0}^{\infty}x^{i}[/tex]
Hence, we have:
[tex]F(x)=\frac{d}{dx}(x^{2}\frac{d}{dx}\frac{1}{1-x})-x\frac{d}{dx}\frac{1}{1-x}[/tex]
or:
[tex]F(x)=\frac{x^{2}+x}{(1-x)^{3}}[/tex]
The sum of the original series is found by evaluating [tex]F(\frac{1}{4})[/tex]
Which is 20/27, as Mathematica magically guessed.
Nice, arildno.
A very clever little trick, indeed.
cookiemonster
I mean the approximation should be an upper bound to the accurate answer to the original question.
Hence, we have:
or:
What are you doing, arildno? You are professional but I do not understand. Why you do like this?
OK, I'll break up this in tiny pieces; then pin-point what you don't understand.
1. Changing perspective from number to function:
We start out with the series:
[tex]S=\sum_{i=0}^{\infty}i^{2}(\frac{1}{4})^{i}[/tex]
Our aim is to find the number S!
However, this is difficult to do as it stands; what I want to do, is to change the problem slightly, so that:
a) I gain access to powerful solving techniques in the new problem to be solved
(which is not accessible in the original problem)
b) I can easily find the answer to the original problem once I have found the answer to the new problem
That is why I change perspectives to try to simplify the expression for the following function:
a): Since I now have a power series function , I can use the extraordinarily powerful teqnique of differentiation to help me solve the new problem (simplifying the expression for F(x)!)
b) If I can do this, then I can find the answer to my original problem simply by
computing [tex]F(\frac{1}{4})[/tex]
I'll let you ponder on this for a while, if you have some specific questions, pleasy notify..
  • · Replies 31 ·
  • · Replies 40 ·
  • · Replies 26 ·
