Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Other Sciences > Biology
Reply
image Breathing pure oxygen Share It Thread Tools Search this Thread image
Old Jun14-09, 01:39 PM                  #1
leroyjenkens
leroyjenkens is Offline:
I've heard that breathing pure oxygen is bad for you, but I can't find any information about it online. Is it bad?
Do scuba divers and astronauts breathe pure oxygen or is it diluted with other gases?
Old Jun14-09, 01:54 PM                  #2
Borek
Borek's Avatar
Best Humor 2008
Borek is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Re: Breathing pure oxygen
Oxygen poisoning.
Too high partial pressure in the air leads to seizures and blackouts, together with uncontrolled cotractions of muscles.
You can still breathe pure oxygen, just its pressure must be low enough.
Old Jun14-09, 02:13 PM                  #3
jamesb-uk
jamesb-uk is Offline:
Even when a patient is put 'on oxygen', the gas they are breathing is not pure oxygen, it just has a higher % in it. The lungs are generally very efficient at getting oxygen out of the air and into the blood;I heard that the red blood cells leaving the lungs are about 98% saturated with it, so breathing more oxygen is not going to do a huge deal of good to a healthy person.
Old Jun14-09, 05:11 PM                  #4
Andy Resnick
Andy Resnick is Offline:
Recognitions:
I've asked a few docs about this at work, it does seem counterintuitive that too high a percentage oxygen is just as bad as too low a percentage. We decided that the problem is that a too-high O2 concentration displaces CO2 in the blood and tissues; this changes the pH- and that is the problem: an off-nominal pH.
Old Jun14-09, 05:22 PM                  #5
Borek
Borek's Avatar
Best Humor 2008
Borek is Offline:
Recognitions:
Could be - no idea what the physiological mechanism is, but I have seen results at work.
In fact it is enough to hyperventillate for a few minutes to start to feel uncontrolled contractions of muscles - lips at first.
Old Jun15-09, 08:21 PM                  #6
Moonbear
Moonbear's Avatar
Moonbear is Offline:
Recognitions:
Retired Staff Retired Staff
I never gave it considerable thought before, but that makes sense. I was thinking along the lines that Borek was, that without a CO2 signal, hyperventillation would be a problem.
Since the OP also asked about divers, I think the O2 is displaced with nitrogen for divers as they head into deeper depths.
Old Jun16-09, 03:11 AM                  #7
Borek
Borek's Avatar
Best Humor 2008
Borek is Offline:
Recognitions:
When you go deeper nitrogen becomes dangerous as well (see nitrogen narcosis) - thus you don't use nitrogen to dilute oxygen, rather other gases with lower molecular mass (these times in form of mixtures, like trimix or heliox).
Old Jun16-09, 10:31 AM                  #8
Moonbear
Moonbear's Avatar
Recognitions:
Oh, right, helium is definitely in the mix for very deep sea diving. I was watching some show where they had guys working pretty deep to repair oil rigs at sea, and as they communicated with the people on the platform, their voices were all squeaky. It was pretty hilarious, because they were all these big, burly, oil rig working, deep sea diving, manly men type people and talking in these funny, squeaky, high-pitched voices from the helium.
Old Jun16-09, 05:32 PM                  #9
Mech_Engineer
Mech_Engineer is Offline:
Yeah Nitrogen narcolepsy kicks in at around 120-150 ft (3.5-4.5 atmospheres) depending on the person's physiology, so it can't be used for depths below that. I've personally gotten nitrogen narcolepsy at 140 ft before, it felt kind of like being drunk and giddy at the same time.
Old Jun16-09, 06:09 PM                  #10
mgb_phys
Physics Guru 2008
mgb_phys is Offline:
Recognitions:
You only need a partial pressure 0.2atm oxygen to function normally.
You are supposed to only use 100% O2 for a maximum of 24hours, but this is mainly because it irritates the lungs. Most hospital masks are designed to also allow some room air in so you aren't breathing 100% O2
Medical and aircraft bottled oxygen is often 70% O2 (the rest nitrogen) but that's mainly for fire prevention, there are a bunch of plastics and grease/oil that combust in 100% O2.
Higher oxygen partial pressures cause entertaining central nervous system toxicity effects, like convulsions. The limit for O2 in dangerous situations (like underwater) is generally 1.6atm but you can use upto around 3.2atm on the surface in a chamber for short periods.
In diving, down to normal recreational depths (40m) the best thing to use it Nitrox - air with enhanced O2 either 32 or 38% O2. Below 40m Nitrogen narcosis becomes a problem which is why it's the limit for recreational scuba.
Below that you have to remove the nitrogen and replace it with helium = Heliox.
As you go deeper to the point that 21% oxygen would get above 1.6atm you also have to remove some of the oxygen. That gets dangerous because you then have a mix that doesn't have enough oxygen to breathe at shallower depths, so as you descend you have to swap systems. It's a bit safer in commercial diving where someone at the surface (who hopefully isn't as stressed, disorientated and narced) is handling the mixes.
Then as you get much deeper (below 2-300m) helium starts to cause the same CNS symptoms as O2 and you have to replace some of the helium with hydrogen = trimix. With this you can work at 800m!
ps. guess who used to be a diving instructor
Old Jun16-09, 06:12 PM                  #11
mgb_phys
Physics Guru 2008
Recognitions:
I'm not sure that concentration of CO2 triggers breathing, I think it's just partial pressure. There are some people with a low sensitivity to CO2 who need a high concentration to trigger a breath - when you give them oxygen they pass out !
image image
Reply
Thread Tools
Similar Threads for: Breathing pure oxygen
Thread Thread Starter Forum Replies Last Post
Fire in pure oxygen munky99999 Chemistry 2 Apr15-06 06:22 PM
breathing liquids JV Biology 1 Sep24-04 05:31 PM
Could breathing pure oxygen at 3 psi cause rapid heartrates up to 158? Rader Biology 0 Aug9-04 09:04 AM
Breathing Homework celtchic Introductory Physics 1 Nov24-03 06:42 AM
Breathing Perfluorocarbon Liquid Greg Bernhardt Biology 3 Apr28-03 10:20 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
