Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image Verify special relativity by concept "light clock" Share It Thread Tools Search this Thread image
Old Jun17-09, 01:41 PM                  #1
Mark1991
Mark1991 is Offline:
Hello.
For verify the special theory of relativity most books use a "light-clock":
Obviously, the way the light covers, when the clock is moved is bigger, than the way the light covers when the clock is not move.
Because speed of light is constant, time must decrease (when the velocity in not 0).
But what happens with clock which are not based on the principle of constant speed of light?
I mean it would be much easier to say "Light-clocks are not real clocks, because they do not give the right time when they are moved. Despite a pendulum clock seems to be a real clock."
You will say that the theory of special relativity was proofed by atomic clocks which were moved around the world in planes.
Nevertheless, an atomic clocks is based on the principle of constant speed of electrodynamic waves, too: E.g. caesium emits measureable microwaves, lasers are used, etc..
Where is my mistake?
Mark
Old Jun17-09, 01:44 PM                  #2
MeJennifer
MeJennifer is Offline:
Re: Verify special relativity by concept "light clock"
No that is incorrect.
Unaccelerated movement is relative in SR.
Old Jun17-09, 01:48 PM                  #3
Cyosis
Cyosis is Offline:
Recognitions:
Homework Helper Homework Helper
What Jennifer is saying is that you need to specify two frames. One observer in frame 1 sees "something" the other observer in frame 2 sees "something else".
Old Jun17-09, 01:49 PM                  #4
Mark1991
I meant that the ways seems to be bigger for an external observer. When the clock is moved, the ways seems to become bigger, while speed of light remain constant. Hence an external observer follows that time goes faster.
Mark
Old Jun17-09, 01:53 PM                  #5
Mark1991
Yes, I know.
But my problem is to find the reason why special relativity is always true and not only when light-clocks are used.
Old Jun17-09, 02:07 PM       Last edited by Cyosis; Jun17-09 at 02:13 PM..            #6
Cyosis
Cyosis is Offline:
Recognitions:
Perhaps the light clock is a deceptive name. Imagine person A and person B sync there watches, after which person A boards a train. On that train there are two mirrors and a light beam bouncing in between just as in your picture. When the train starts moving person A sees the mirror/light beam assembly like in picture 1. He measures the time it takes for a beam to bounce up and down. Person B sees the clock the way your second picture depicts it. He too measures the time it takes for a light beam to bounce back and forth. They will not agree on the times they measured.
Old Jun17-09, 02:20 PM                  #7
Mark1991
Thank you for your replies.
Why they do not agree? Because special relativity tells us? No, we are not allowed to use the predictions of special relativity as long as we are not sure that the theory is true. (And we want to proof time-dillation with this experiment).
___________________________________________
Old Jun17-09, 02:29 PM                  #8
Cyosis
Cyosis is Offline:
Recognitions:
I didn't use the theory of special relativity as you may think I did. All I used was that the speed of light is constant. From this time dilation will follow for exactly the reason I said.
You said it yourself, although worded poorly, that person B sees the light travel a long distance. Since the speed of light is constant person B will measure the time interval between emitted light and returning light to be longer than person A. After all from person B's view light had to travel less distance.
Old Jun17-09, 02:38 PM                  #9
Mark1991
Thank you, Cyosis.
Nevertheless I think my problem did not become clear.
I will try it again with another experiment:
Assume that there are two clocks on the train.
A real clock and a fake-clock.
The fake-clock ist not a real clock, because it can find out, whether the train is moved (relative to the earth) or not (by "looking" out of the window or s.th like that).
If the train is not moved, the fake-clock will show normal time.
If the train is moved, the fake-clock will show the time t'=t*k (0<k<1).
Assume that the fake-clock is identical with the light-clock!
-> If the light-clock is moved, it gives the wrong time, although no other "real" clock is influenced.
It is not possible to distinguish whether this assumption or special relativity is true.
Again, where is my mistake? :-)
Old Jun17-09, 02:41 PM                  #10
Cyosis
Cyosis is Offline:
Recognitions:
No, in my example person A and B both used a normal clock (no light clock), synced their watches,stepped on the train and did their measurements. The word light clock as you know it was not used at all.
Old Jun17-09, 02:43 PM                  #11
Mark1991
Mh, ok.
Thank you very much.
Old Jun17-09, 02:48 PM       Last edited by Cyosis; Jun17-09 at 02:54 PM..            #12
Cyosis
Cyosis is Offline:
Recognitions:
Keep asking until all doubt vanishes! Special relativity at first is hard, conceptually (not only at first).
Old Jun17-09, 03:12 PM       Last edited by Mark1991; Jun17-09 at 03:17 PM..            #13
Mark1991
Okay, maybe another question:
All opportunities to derive time-dillation has to do something with light.
Even in your derivation you use a light beam, bouncing between two mirrors.
Assume you take a ball which bounce between two walls with the velocity 0,5 c. The distance between the walls is only half of the distance of the mirror, so that the event of reflecting the light beam and the reflecting of the ball are always at the same time.
The speed of light is constant for every observer, the speed of the ball obviously not.
An outstanding observer sees that the travelled distance of the light rises, because speed is constant -> time-dillation
The travvelled distance of the ball rises, too, but the speed of the ball is not constant.
-> Changing of the ball's velocity (rises).
Where do we find the time-dillation in the "ball-clock"?
Why are you such an expert in special relativity? Do you/ Did you study physics?
Mark
Old Jun17-09, 03:44 PM                  #14
JesseM
JesseM is Offline:
Recognitions:
PF Contributor PF Contributor
Mark1991, are you aware that SR is based on two fundamental postulates, the first of which says all laws of physics should work the same in every inertial frame (meaning if two observers are in windowless ships moving inertially relative to one another, and they both perform the same experiment on board their own ship, they should always see the same result), and the second of which says the speed of light is the same in every frame? You have only been talking about the second postulate, but it's the first postulate that makes clear why non-light-clocks should be expected to agree with light clocks (assuming the postulates actually hold true of course). If you place a non-light-clock at rest next to a light-clock in one inertial frame and they keep the same time, then this still must hold true if you do the same experiment in any other inertial frame.
Old Jun17-09, 04:02 PM                  #15
Mark1991
Yes, I know thar the theory of special relativity is based on this postulates.
By the way: Why we kann be really, really sure that laws of relativity must work in every inertial frame? Only the fact nobody ever has observed an inertial frame, in which laws of physics does not work, does not proof that the postulate is true, does it?
Old Jun17-09, 04:08 PM                  #16
JesseM
JesseM is Offline:
Recognitions:
OK, so do you see why a non-light-clock should experience the same time dilation as a light clock if the two postulates are both true?
We can't be totally sure, but we can check whether the equations of the fundamental laws of physics as expressed in one inertial frame have the mathematical property of "Lorentz symmetry", if they do that means they'll obey the same equations in all the other inertial frames related to the first one by the Lorentz transformation. All the fundamental laws of physics we know of today have this property.
image image
Reply
Thread Tools
Similar Threads for: Verify special relativity by concept "light clock"
Thread Thread Starter Forum Replies Last Post
Question about "A Calorimetric Test of Special Relativity" lalbatros Special & General Relativity 6 Mar7-09 07:01 AM
Open poll on "What changes for special and general relativity?" Juan R. General Physics 31 Jan19-08 06:00 AM
Are "two line derivations" harmful in teaching special relativity bernhard.rothenstein Special & General Relativity 8 Jan4-07 10:46 PM
"On the concept of mass on relativity" Pmb General Physics 0 Nov4-06 04:25 PM
Paper - "On the concept of mass in relativity" pmb_phy Special & General Relativity 0 Dec23-05 04:29 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
