Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image Well-ordering of reals Share It Thread Tools Search this Thread image
Old Jun19-09, 06:04 PM                  #1
Ookke
Ookke is Offline:
If < is any total order in R, isn't it always possible to construct an infinite sequence
x1 > x2 > x3 > ... > y for some limit point y in R.
It seems to me that {x1, x2, x3, ...} is then a subset of R that does not have
least element in this ordering. No total order in R can be well-order?
Old Jun20-09, 09:29 AM                  #2
Preno
Preno is Offline:
Re: Well-ordering of reals
The axiom of choice says that such a sequence exists. You may or may not accept that axiom.
Old Jun20-09, 09:53 AM                  #3
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Why would it?
Do keep in mind that a total order on R does not have to bear much resemblance to the usual order.
Old Jun20-09, 03:26 PM                  #4
Ookke
Ookke is Offline:
Originally Posted by Hurkyl View Post
Why would it?
It's just an intuition of that uncountable set is necessarily kind of dense for any order, not just the common order.
I had in mind two assumptions which seem quite natural:
1. Uncountable set of reals must have uncountable interval (a,b) for any order <.
2. It's always possible to split uncountable interval into two parts, both uncountable.
Then what follows, we can split (a,b) into two parts, select x1 from the upper part. Then split lower part again into two parts, select x2 from the new upper part, and so on. This way should be formed a sequence {x1, x2, ...} where x1 > x2 > ... for the order <, and the sequence does not have a least element.
I'm just developing the idea, but if this is already flawed, I would appreciate any point.
Old Jun20-09, 04:40 PM                  #5
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
This is demonstratably false, by a rather slick argument. It depends on two facts:
(1) The class of all ordinal numbers is well-ordered
(2) There exists an uncountable ordinal
Therefore, there exists a smallest uncountable ordinal number; let's call it LaTeX Code: \\omega_1 .
Now, consider the (uncountable) half-open LaTeX Code: [0, \\omega_1) of ordinal numbers. If you choose any ordinal LaTeX Code: \\alpha in this interval, we have:
* LaTeX Code: [0, \\alpha] is countable,
* LaTeX Code: [\\alpha, \\omega_1) is uncountable.
In particular, every Dedekind cut of LaTeX Code: [0, \\omega_1) has a countable lower part.
Old Jun20-09, 05:01 PM                  #6
Ookke
Ookke is Offline:
Ok, thanks. Had fun trying, now I need to learn some ordinals.
Old Jun20-09, 05:22 PM                  #7
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
Since you're researching it anyways -- it might interest you to look at another counterexample you can create using LaTeX Code: \\omega_1 : the long ray.
Old Jun22-09, 03:30 PM                  #8
Ookke
Ookke is Offline:
I found an interesting article about smallest uncountable set:
http://www.math.fsu.edu/~bellenot/cl.../omega-one.pdf
From there, I understood that it's possible to have uncountable set X for which every LaTeX Code: seg(y) = \\{x\\in X | x < y\\} is countable. This is exactly against an idea I had for proving my second assumption (yes it hurts, but I don't care).
But why is it impossible to have a sequence LaTeX Code: \\{x_n\\} in X that takes up the whole X, i.e. for any x, LaTeX Code: x < x_n for large enough n?
Existence of such a sequence seems almost obvious to me, and this would be enough to prove X as union of LaTeX Code: seg(x_n) countable. Or is it just that because of initial assumptions, we must deny this kind of sequences. Do you happen to know any "real-world" example where any sequence cannot take the whole set?
Old Jun22-09, 05:54 PM                  #9
Hurkyl
PF Mentor
Hurkyl's Avatar
Hurkyl is Offline:
And since we know LaTeX Code: \\omega_1 isn't countable, that tells you why it's impossible.
If this seems obvious to you, that just means your intuition isn't equipped to deal with orders of uncountable cofinality. ("cofinality" measures this quality of orders)
"Real world" is very much in the eye of the beholder. As I mentioned in my previous post, LaTeX Code: \\omega_1 can be used to construct counterexamples, such as the long ray -- which tells geometers if they want to study more "normal"-looking spaces, they need to require that manifolds aren't merely Hausdorff and locally Euclidean... one must also insist on second countability.
I've personally explicitly used uncountable ordinals in proofs because my preferred method of applying the axiom of choice is to use the well-ordering theorem along with transfinite iteration1.
I've also explicitly used them to help understand nonstandard analysis. (In particular, to understand just how ugly the hyperreals look when studied externally)
1: This refers to a form of transfinite induction that I find particularly natural, but I don't think it's a standard term.
image image
Reply
Thread Tools
Similar Threads for: Well-ordering of reals
Thread Thread Starter Forum Replies Last Post
|P(N)| = |Reals| Unassuming Calculus & Beyond 1 Feb13-09 06:23 AM
Find all reals: Euler_Euclid General Math 11 Sep7-08 02:58 PM
Well-ordering of the reals mathboy General Math 16 May20-08 11:00 AM
Well-ordering of the Reals dmuthuk Set Theory, Logic, Probability, Statistics 4 May2-08 10:15 AM
Contruction of the Reals? Gale Introductory Physics 7 Sep26-05 11:16 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
