Incredible Power of Oil: Stick Diamonds to Windows!
The discussion centers on the phenomenon of using oil from behind the ear to adhere diamonds to surfaces, such as windows. The smooth surface of diamonds creates an airtight seal when coated with oil, resulting in strong adhesive properties. This effect is attributed to the film pressure or disjoining pressure of the oil, which allows for significant adhesion between two flat objects. The conversation also touches on related concepts like gauge blocks and the behavior of clean surfaces in vacuum conditions.
  • Understanding of fluid mechanics, specifically film pressure and disjoining pressure.
  • Knowledge of material properties, particularly the characteristics of diamonds.
  • Familiarity with adhesion principles in physics and engineering.
  • Basic comprehension of vacuum conditions and their effects on surface interactions.
  • Research the principles of film pressure in fluid mechanics.
  • Explore the properties of diamonds and their applications in adhesion technologies.
  • Learn about adhesion mechanisms in vacuum environments.
  • Investigate the behavior of gauge blocks and their significance in precision engineering.
This discussion is beneficial for physicists, materials scientists, and engineers interested in adhesion phenomena and the unique properties of diamonds in practical applications.
katchum
I read on the news that when you place oil from behind your ear onto the diamond. You can stick it to the window and the adhesive power will be so strong that you can place a metal pincet on it.
Any explanation?
http://www.standaard.be/video/videoPlayer.aspx?cat=1&subcat=1&videoId=352871
If I were to speculate, the reason why may be due to the surface of the diamond. Since a diamond is very hard and compact, the surface would be very smooth and not have a lot of crevices or cracks (on a microscopic scale).
Because of that, if the diamond were to be covered in oil and stuck to a wall, the oil would cause an air-tight seal that would be very hard to break due to the smooth surface of the diamond.
Any explanation?
I don't know what a 'pincet' is, but thin layers of fluid can adhere two flat objects together with surprising strength. For example, one must be careful when handling 'gauge blocks' so that they do not adhere and become useless. This is also a problem (but a slightly different mechanism) with very clean surfaces that contact in vacuum- they can essentially weld themselves together.
The origin is the film pressure or disjoining pressure of the fluid- the extreme curvature of the edges of the film implies a very high pressure difference between the fluid and outside, and the thin film resists tearing.
  • · Replies 69 ·
18K
  • · Replies 19 ·
11K
  • · Replies 19 ·
10K
