Speed of car with changing mass problem
  • Thread starter Thread starter bodensee9
    Car Mass Speed
The problem involves calculating the speed of a freight car with changing mass due to sand being added at a steady rate. The initial mass of the car is denoted as M, and the mass of sand added over time is represented by the function M(t) = M + bt, where b is the rate of sand flow. The correct formula for speed, derived from the integration of the force equation, is v = (F/b) * ln((M + bt)/M). The initial condition at t = 0 must be considered to ensure the accuracy of the solution.
  • Understanding of Newton's second law of motion
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of variable mass systems in physics
  • Basic principles of kinematics
  • Study variable mass systems in classical mechanics
  • Learn integration techniques for solving differential equations
  • Explore applications of logarithmic functions in physics
  • Review examples of force and motion problems involving changing mass
Physics students, educators, and anyone interested in dynamics and kinematics involving variable mass systems.
bodensee9
Hello:
An empty freight car of mass M starts from rest under an applied force F. At the same time, sand begins to run into the car at steady rate b from a hopper at rest along the track. Find speed when mass of sand m has been transferred.
I have attached a drawing.
So would this be: Let M(t) = mass as a function of time. So we have
M(t) = M + bt
And we have F = M(t)(dv/dt)
So F(dt) = M(t)dv
or dv = F(dt)/(M + bt)
So wouldn't we have
v = F/b*ln(M + bt)?
But somehow this is wrong?
Thanks.
You've got it right up to dv = F(dt)/(M + bt)
By doing a substitution of "M + bt" and then integrating accordingly, you should get
v = (F/b)*ln((M + bt)/M)
I think all that you did wrong was that you forgot to solve for the "t = 0" end of the integral.
  • · Replies 27 ·
  • · Replies 42 ·
  • · Replies 24 ·
