What is the Height of the Cart When It Stops Rolling Up an Inclined Board?
The problem involves a cart that rolls across a table and then up an inclined board, ultimately coming to rest. The context includes concepts of energy conservation, specifically relating spring potential energy to gravitational potential energy.
  • Participants discuss the conservation of energy as a potential approach, with some suggesting the conversion of spring energy to gravitational potential energy. Questions arise regarding the necessary formulas and the initial conditions of the system.
There is an ongoing exploration of the relationship between kinetic energy, potential energy, and spring energy. Some participants express uncertainty about the details and assumptions of the problem, while others provide guidance on relevant equations.
Participants note a lack of sufficient information for calculations and question the assumptions regarding the initial state of the spring-cart system.
Walid11
125N of force are required to compress a spring by 1.04m. The cart rolls across the table at a constant speed. It then rolls up an inclined board and comes to rest. How high above the table is the cart when it stops?
Walid11 said:
Conservation of energy might aid you here.
There's not enough information to make any calculations. But from what I can tell from the problem, it's just the conservation of spring energy to potential energy.
well it moves at 9.3 m/s horizontally
Then it's conservation of Kinetic Energy to Potential ...
what's the formula for that?
Well, kinetic energy is (1/2)mv^2 and potential energy is (1/2)kx^2. Have you seen these equations before?
Uhm I assume the spring-cart system is initially at rest. So then you want all the potential energy of the spring to be converted into gravitational pe (mgh). You need to get h.
yeah, i just couldn't differentiate. Thank you
Oops, I didn't read the question and assumed the potential energy bucher was talking about was spring potential energy. Apologies!
