Help with making an orthonormal basis
  • Context: Undergrad
  • Thread starter Thread starter graphic7
    Basis Orthonormal basis
The discussion revolves around forming an orthonormal basis from two non-parallel vectors using the Gram-Schmidt process. Participants explore the calculations and concepts involved in orthogonalization and vector projection.
  • One participant requests guidance on forming an orthonormal basis from the vectors a = (3, 4) and b = (2, -6).
  • Another participant shares their struggle with visual explanations of vectors and expresses a preference for clearer mathematical reasoning.
  • A participant suggests using the Gram-Schmidt process and provides a formula for the projection of vector a onto vector b, stating that the orthogonal vector can be derived from this projection.
  • Calculations are presented for finding the orthogonal vector to b, leading to the conclusion that the two vectors can serve as basis vectors after normalization.
  • One participant explains the reasoning behind the projection formula, relating it to the geometric interpretation involving the angle between vectors and the use of unit vectors.
Participants generally agree on the use of the Gram-Schmidt process and the projection formula, but there is no explicit consensus on the best approach to visualizing or understanding these concepts.
Some participants express uncertainty regarding visual representations of vectors and the clarity of explanations, indicating a potential limitation in understanding the geometric aspects of the problem.
graphic7
I'm wanting to form an orthonormal basis from two non-parallel vectors.
[tex]a = \left(\begin{array}{cc}3 & 4\end{array}\right)[/tex]
[tex]b = \left(\begin{array}{cc}2 & -6\end{array}\right)[/tex]
Could someone please walk me through the calculations needed? Much appreciated.
I think I've finally figured out. I had it explained to me visually, which didn't make sense. By visually, I am referring to the whole vector "arrow" idea which always troubles me.
Look up the Gram-Schmidt process.
Or consider the image I've attached. The vectors are probably pointing in the wrong directions, but it doesn't really matter. The red vector (call it [tex]a_o[/tex]) is orthogonal to b, and the green vector (call it [tex]a_p[/tex]) is parallel to b. Now, a_p is the projection of a onto b, and there's a nice formula for finding it:
[tex]a_p = \frac{a.b}{b.b} * b[/tex]
(It's easy to prove, see any linear algebra text). After some calculations, we find that [tex]a_p = \left(\begin{array}{cc}-9/10, & 27/10\end{array}\right)[/tex]. But since [tex]a = a_p + a_o[/tex], we have that [tex]a_o = a - a_p = \left(\begin{array}{cc}3, & 4\end{array}\right) - \left(\begin{array}{cc}-9/10, & 27/10\end{array}\right) = \left(\begin{array}{cc}39/10, & 13/10\end{array}\right)[/tex]. And so, we have "created" a vector that's orthogonal to b, so you can chose a_o and b as the basis vectors. (Of course, you've got to normalize them first, but that's trivial).
Thanks very much for the explanation. Orthogonalization makes quite a bit more sense now. I've done some visual graphs with Mathematica, and that's helped quite a bit, also.
the reason the projection of a onto b is ghiven by that formula is because of the familiar formula a.b = |a| |b| cos(C) where C is the angle between a and b. I.e. from triangle trig, the projection of a onto b has length |a| cos(C). so the vector of that length in that direction is obtained by multiplying a unit vector by that length. Now of course b/|b| is a unit vector in the direction of b,
so the vector parallel to b, with length |a| cos(C), is the product
|a|cos(C) b/|b| = |a||b| cos(C)/|b|^2 b = (a.b/b.b) b.
  • · Replies 23 ·
  • · Replies 19 ·
