Electron moving through a uniform magnetic field
An electron moving at a speed of 9.00 x 105 m/s in a uniform magnetic field of 2.0 T experiences an upward magnetic force of 2.00 x 10-14 N. Using the equation F = |q| * v * B * sin(θ), the angle of the electron's movement was calculated to be 3.98° counterclockwise from south, resulting in a second position angle of 183.98° instead of the initially assumed 177.02°. The correct interpretation hinges on the properties of the sine function, specifically that sin(180º + θ) results in a negative value, while sin(180º - θ) retains the positive value.
  • Understanding of electromagnetic forces, specifically Lorentz force
  • Familiarity with trigonometric functions, particularly sine
  • Knowledge of basic physics concepts related to charged particles in magnetic fields
  • Ability to manipulate equations involving force, charge, velocity, and magnetic field strength
  • Study the Lorentz force law in greater detail
  • Explore the properties of the sine function in trigonometry
  • Learn about the motion of charged particles in magnetic fields
  • Investigate applications of magnetic fields in particle physics
Students and educators in physics, particularly those focusing on electromagnetism and the behavior of charged particles in magnetic fields.
bioradical
The Problem:
An electron moves with speed 9.00 105 m/s in a uniform magnetic field of 2.0 T, pointing south. At one instant, the electron experiences an upward magnetic force of 2.00 10-14 N. In what possible directions might the electron be moving at that instant? Give your answers as angles clockwise from south (from 0° to 360°), in increasing degrees.
The only equation needed should be F= lql * VBsin(theta)
I used the above equation and found the angle to be 3.98° counterclockwise of South. So my first answer was 360-3.98=356.02° (which was correct). My problem came with finding the angle at the second position. I initially thought that it would be 180-3.98, but, through guess work, I found that the correct answer is 180+3.98= 183.98. I'm not sure why this is right.
Can someone help me understand the concept behind the second possible position of the electron?
Thank you!
Welcome to PF!
Hi bioradical! Welcome to PF! :smile:
Because what matters is sinθ.
sin(180º + θ), which was your first try, is minus sinθ (so the force would have to be down) …
but sin(180º - θ) is sinθ :wink:
  • · Replies 31 ·
