Originally Posted by Eshi
My boss ssaid possibly its the order of reagents, but why would that reduce the bioluminescence?
P.S. I am only a freshman in college, so my knowledge of biochem is limited. WHere should i go to learn more about this type of thing? or could someone help?
Unfortunately, I share ePenguin's confusion in trying to understand the sentence describing your experiment and results.
However, since you are a freshman, I assume you are doing this as an internship type project to learn more about research. If so, you should be able to ask your "boss" if you don't understand his/her explanation. S/he knows what you've been trying to do better than we do, so should be able to explain her/his reasoning to you, or offer you some resources to learn some of the basics you need to understand the subject.
Otherwise, if you want help here, you're going to need to provide a lot more information, such as what reagents you're using, the order you're using them, the conditions of the reaction, etc. Importantly, what are your controls? You said the reaction is a two-step process, and it sounds like you mean that luciferan and ATP are each substrates for the reaction in wild type, but not that they necessarily need to both be present at the same time. Is that correct? Do you first react with luciferan, then ATP, or vice versa? Or do both need to be present together? How do you know your mutant is capable of using both substrates? If it uses luciferan, but you have lower luminescence in the presence of ATP when comparing with wild type, how have you ruled out that the mutation isn't leading to a defect in ability to use ATP as a substrate?
