Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
image poisson and uniform paradox Share It Thread Tools Search this Thread image
Old Jun23-09, 09:37 AM                  #1
benjaminmar8
benjaminmar8 is Offline:
Hi, all,
Let's say we deploy some random points on a line of finite length according to a poisson distribution of density \lambda. Can I say that these points are also "uniformly" distributed on the same line?
thks
Old Jun23-09, 05:51 PM                  #2
HallsofIvy
PF Mentor
HallsofIvy is Offline:
Re: poisson and uniform paradox
Originally Posted by benjaminmar8 View Post
Hi, all,
thks
No, you can't. (And there is no "paradox".) With Poisson distribution, with parameter LaTeX Code: \\lambda , points are as likely to be LaTeX Code: \\le \\lamba as larger. With a "uniform" distribution, they are as likely to be less than or equal to the midpoint of the interval as to be above it. Further, points in a Poisson distribution are more likely to be close to \lambda than not while there is no number in an interval that points in a uniform distribution are more likely to be close to.
Old Jun23-09, 06:02 PM                  #3
mXSCNT
mXSCNT is Offline:
The Poisson distribution gives the waiting time until the next event. I think he means, distribute points randomly along an interval such that their _waiting times_ are distributed as Poisson random variables.
The resulting distribution of points is similar to what you would get if you sampled the same number of points from a uniform distribution along the same interval. There's at least one important difference, however: if you choose points with waiting times according to the Poisson distribution, you don't know when starting out how many points are going to fit in the interval.
Old Jun30-09, 06:09 PM                  #4
gel
gel's Avatar
gel is Offline:
Recognitions:
PF Contributor PF Contributor
That doesn't make sense, the Poisson distribution is unbounded, so not confined to a random line. Maybe you mean a random (and finite) set so that the number of points in any interval (a,b) is Poisson distributed with parameter LaTeX Code: \\lambda(b-a) ? i.e., a Poisson random field or Poisson random measure.
Then, yes, you get the same thing as choosing N independent and uniform random variables, where N itself has the Poisson distribution.
(I don't see any paradox...)
Old Jul2-09, 09:53 PM                  #5
bpet
bpet is Offline:
To be more precise, for a Poisson process (where the interarrival times are exponential) given that there are N arrivals in [0,T] the arrival times T1,...,TN will be distributed according to the order statistics of N independent uniform variables.
image image
Reply
Thread Tools
Similar Threads for: poisson and uniform paradox
Thread Thread Starter Forum Replies Last Post
Poisson RV forty Calculus & Beyond 2 Jun11-09 05:43 PM
The Twin Paradox Paradox. jujufactory Special & General Relativity 3 Dec28-07 11:05 AM
Resolving the Barber Paradox and the Russell's Paradox Owen Holden Philosophy 18 Apr3-05 05:07 AM
What is the resolution of the The Bug-Rivet Paradox paradox in special relativity? yxgao Special & General Relativity 4 Dec18-04 01:04 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
