Pendulum problem helpfinding weight
  • Thread starter Thread starter jmb07
    Pendulum Weight
The discussion centers on calculating the weight of a fish using a spring and oscillation data. Martin used a 4.6 N weight to determine the spring constant by measuring the oscillation frequency of the spring. The spring oscillated 20 times in 65 seconds with the known weight, allowing the calculation of the spring constant (k). By applying the same spring constant to the fish's oscillation, which took 220 seconds for 20 oscillations, the weight of the fish can be determined using the derived equations.
  • Understanding of harmonic motion and oscillation frequency
  • Knowledge of Hooke's Law and spring constants
  • Familiarity with the formula for angular frequency (ω = √(k/m))
  • Basic algebra for solving equations with one unknown
  • Calculate the spring constant (k) using the oscillation data from the 4.6 N weight
  • Apply the derived spring constant to find the weight of the fish using its oscillation data
  • Explore the relationship between mass and oscillation frequency in spring systems
  • Investigate real-world applications of spring oscillation in physics experiments
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for practical examples of spring dynamics.
jmb07
Martin caught a fish and wanted to know how much it weighed, but he didnt have a scale. He did however have a stopwatch, a spring, and a 4.6 N weight. He attached the weight to the spring and found that the spring would oscillate 20 times in 65 s. Next, he hung the fish on the spring and found that it took 220 s for the spring to oscillate 20 times. What is the weight of the fish?
I know that omega=sqaure root of (k/m)
However, I just have no idea how to start or apply this equation to solve this problem.
Apply the equation to both cases
You know K is the same
You know the frequency in both cases
So you can write two equations with only one unknown - the second mass
This is a typical spring question. Instead of telling you the spring constant directly they give you some information from which you can first derive k. Then you can reduce the problem to the basic "He hangs the fish on a spring with spring constant <fill in number you just calculated> N/m and found that it took 220 s for the spring to oscillate 20 times. What is the weight of the fish?"
  • · Replies 27 ·
