Bloch's theorem for finite systems ?
  • Context: Graduate
  • Thread starter Thread starter |squeezed>
    Finite Systems Theorem
The discussion revolves around the application of Bloch's theorem (or Floquet's theorem) to finite, periodic structures in solid state physics. Participants explore the physical correctness of using Bloch's theorem in finite systems, particularly in the context of boundary conditions and the implications of periodicity.
  • One participant questions the physical correctness of applying Bloch's theorem to finite structures, particularly regarding boundary conditions and the necessity of cyclic conditions for the theorem to hold.
  • Another participant notes that while finite systems are complex, textbooks often assume a large N limit, suggesting that corrections for finite N exist but may not always apply.
  • A different viewpoint emphasizes that finite and periodic are technically distinct, arguing that Bloch's theorem is applicable under specific conditions, such as the Born-von Karman boundary condition, which allows for periodicity in finite systems.
  • One participant asserts that using Bloch's theorem for finite periodic structures is valid in practice, especially in computational methods for studying defects in crystals, but acknowledges that this approach may not fully capture the reality of defects in actual materials.
Participants express differing views on the appropriateness of applying Bloch's theorem to finite systems. While some argue it can be used effectively under certain conditions, others highlight the limitations and nuances involved, indicating that the discussion remains unresolved.
Participants note that the definitions of finite and periodic may not align perfectly, and the application of Bloch's theorem may depend on specific boundary conditions and the scale of the system being considered.
|squeezed>
Hi all
I have a question regarding Bloch's theorem (also known as Floquet's theorem) and its use. I have seen in many solid state textbooks the famous problem of N coupled oscillators where one finds the dispersion relation analytically by using Bloch's theorem. However many times, authors add the comment that N tends to infinity.
My question is:
Is it "right" to use Bloch's theorem for finite,periodic structures ?
By "right" i mean if it is physically correct - not if one can do that as an approximation.
To my understanding (so far) Bloch's theorem has also to do with the boundary conditions (right?). In a finite structure there would be a problem at the endpoints unless the boundary conditions are cyclic. Then the theorem works, but can one do the same in a more general case without cyclic boundary conditions ?
Thanks
The study of finite-sized systems is massive and complicated. Any textbook on basic condensed matter will always work in the limit where N is very large. In most cases, you can expect a 1/sqrt(N) correction for very large but finite N. (There are times when this breaks down, but they are active research directions.)
In the strictest sense of the definitions, finite and periodic are mutually exclusive, so I assume you mean a finite structure which is approximately periodic in some region of space. Mainly I'm being pedantic on this point because you are asking a pedantic question of whether it's "right" to use Bloch's theorem rather than is it just approximate, and below where I use the term periodic, I really mean periodic in the mathematical sense, ie. periodic over the entire space.
For a free particle in quantum mechanics, you find that the momentum is a good quantum number, and this follows from the infinitesimal translational symmetry in space. The cyclic boundary condition you refer to that makes a finite solid periodic is generally called the Born-von Karman boundary condition, and from it you can derive Bloch's theorem. There you find the pseudo-momentum vector k is a good quantum number, and this follows from the discrete translational symmetry of space in a periodic solid. If you don't have the periodicity, you break the translational symmetry and k is no longer a good quantum number (very strictly speaking, of course).
Realistically, in a solid, 100 unit cells, ~50 nm or so is usually more than enough for the electrons to feel as if they are in an infinite periodic crystal. So Bloch's theorem works to a very excellent approximation for bulk properties of a crystal that is anywhere near macroscopically sized, and there is a whole crapload of experiments which show this.
|squeezed> said:
Hi all
Of course. This is how a lot of ab-initio codes that handle infinite systems work. This is how one does a calculation on a defect in a crystal. So to answer your question: It is right because it gives the correct answer, but it isn't "real" in the sense that in a real material defects would be repeated in a orderly fashion throughout space.
  • · Replies 20 ·
15K
