Is Minimal CFT Essential for Understanding String Theory?
The discussion revolves around the utility of minimal Conformal Field Theory (CFT) in the context of string theory. Participants explore its relevance, particularly in relation to toy models and its application in various theoretical frameworks.
  • Some participants question the usefulness of minimal CFTs in string theory, noting their primary application in studying toy models.
  • One participant mentions that non-critical toy models in less than one dimension have been used to describe solvable models on Calabi-Yau manifolds, but these models are not minimal.
  • Another participant highlights the real value of minimal models in two-dimensional statistical physics, citing experimental realizations.
  • A participant clarifies that minimal models are a subset of Rational Conformal Field Theories (RCFT), which have a finite number of primary fields and specific central charge constraints.
  • There is a question raised about the relevance of extended minimal or RCFT models, particularly regarding their finite conformal blocks.
  • One participant argues that RCFTs emphasize algebraic structures that may not be significant when the theory is deformed, contrasting this with the continuous parameter families of string vacua.
  • Another viewpoint suggests that while RCFTs allow for exact solvability of correlation functions, topological string theory is seen as more interesting due to its focus on continuous deformations and dualities.
  • A participant seeks clarification on how masslessness contributes to the solvability of CFTs, linking it to supersymmetry and special geometric structures.
  • It is noted that the massless subsector allows for the computation of correlation functions, which is a different approach from that of RCFTs.
Participants express differing views on the significance of minimal CFTs and RCFTs in string theory. While some see limited relevance, others highlight their importance in specific contexts. The discussion remains unresolved regarding the overall utility of these frameworks.
Participants mention that the structure of RCFTs may change under perturbations, which could affect their applicability in string theory. There is also a distinction made between the solvability of massless subsectors and the characteristics of RCFTs.
crackjack
How useful is the framework of minimal Conformal Field Theory (ie. CFTs with finite primary fields) in String Theory?
From what I have come across, I have only seen its usefulness in studying toy models of minimal string theory.
Right.. non-critical toy models in less than one dimension. Tensor products of (supersymmetric) minimal models were used to decribe exactly solvable models on Calabi-Yau manifolds, but these tensor products aren't minimal any more. Minimal models per se are not too interesting or important in string theory.
The real value of minimal models is in 2D statphys, where they have been realized experimentally e.g. in monolayers of noble gases on a graphite substrate.
Just as a sidenote, the class of CFT's with a finite number of primary fields are called Rational Conformal Field Theories (RCFT). The word 'rational' comes from the fact that all fields carry a conformal dimension equal to some fractional number (the same goes for the central charge).
The minimal models are a special subset within these CFT's, namely the central charge falls in the regime 0 < c < 1.
But I don't know anything about it's application to string theory (apart from the fact that CFT's arise as theories which describe the worldsheet dynamics).
Oh ok.
Is this (not-of-much-use-in-strings) the case even for extended minimal (or RCFT) models? - like those with finite conformal blocks (rather than finite individual primary fields)?
crackjack; said:
Oh ok.
Sure, just the same. Each RCFT is minimal with respect to its maximal chiral algebra. So the question essentially is whether RCFTs play an important role. Probably the answer depends whom you ask. I would say, RCFTs are non-generic and emphasize an algebraic structure (namely the one of the extended chiral algebra) that goes away the moment you deform the theory, even slighly. That goes against the spirit of studying continuous parameter families of string vacua.
So there are two schools of thought/taste: the RCFT people study isolated points in the full parameter space (typically with extra symmetries), the benefit being an exact solvability of the CFT and thus in principle, of all correlation functions at a given point. Opposite to this spirit is topological string theory, where one solves only a subsector of the theory (roughly speaking the massless one, which is the relevant one), but as continuous deformation family over the moduli (vacuum parameters) of the theory. Most people find the latter more interesting and important, as for example questions about dualities can be addressed there, while algebraic considerations (RCFT, that is) tend not to be useful. One might loosely say that geometry beats algebra, but that's surely also a matter of taste.
Ok. I think I get you.
When you say one solves the massless case (as against RCFT for a particular parameter), I assume you meant solving for the correlation functions using CFT. So, how does masslessness make CFT solvable? (maybe a sketch or a reference to some book)
From an earlier post above I gather that this masslessness cannot result in finite primary fields.
PS: I recently started on string theory.
It is supersymmetry what is used, CFT only indirectly. More precisely, there is a special subsector in the theory which has special properties, which allows to solve the theory for this subsector (ie, compute the correlation functions, depending on continuous moduli). This "massless" subsector may be called topological, or BPS, or chiral primary, or holomorphic, etc. There is some special geometric structure which makes it "integrable", ie, one can determine the correlators by geometry, which boils down to solve certain differential equations, and/or perfom integrals. As said, this philosophy is in a sense opposite to the one of RCFT, whose structure discontinuously jumps under the smallest perturbations.
Ah ok. Thanks.
  • · Replies 26 ·
  • · Replies 30 ·
12K
  • · Replies 47 ·
10K
