What is the magnitude of the magnetic field?
The magnitude of the magnetic field can be calculated using the formula B = torque / (n * i * A * sin(theta)). In this case, a rectangular coil with 37 turns, an area of 36 cm² (0.0036 m²), and a current of 0.8 A is subjected to a torque of 0.07 Nm at an angle of 18°. The correct calculation requires using sin(72°) instead of sin(18°) due to the relationship between the angle and the normal to the coil. The final result for the magnetic field strength is determined by substituting these values into the equation.
  • Understanding of magnetic fields and torque
  • Familiarity with the formula for torque in magnetic coils
  • Knowledge of trigonometric functions, specifically sine and cosine
  • Ability to convert units from cm² to m²
  • Learn about the principles of electromagnetism and magnetic fields
  • Study the derivation and applications of the torque formula for coils
  • Explore the significance of angles in magnetic field calculations
  • Practice converting between different units of area and force
Students studying physics, particularly those focusing on electromagnetism, as well as educators looking for practical examples of magnetic field calculations.
mba444
What is the magnitude of the magnetic field??
A small rectangular coil composed of 37 turns
of wire has an area of 36 cm2 and carries a
current of 0.8 A. When the plane of the coil
makes an angle of 18◦ with a uniform magnetic
field, the torque on the coil is 0.07 Nm.
field? Answer in units of T.
Torque = n*i*A*B*sin(theta)
B= torque/(n*i*A*sin(theta))
n is the number of turns
what i did is that i plugged all the given values .. but i keep get the wrong answer .. i don't know where is my mistake
thanx in advance
Did you convert the area to m2?
theta is the angle made between the normal to the coil to the magnetic field. Think about it, if the coil is parallel to the magnetic field (theta = 0), the torque is maximum (the forces on the wires are directly opposite), as opposed to if you used sin 0 = 0, that is torque = 0. So you have to use sin 72 or cos 18 in the equation.
I don't even know if that's the problem, but I hope it helps.
  • · Replies 37 ·
