Originally Posted by stone1
I have a similar question (if not the same question really). If there is no space and there is no time, but only spacetime, why do people talk about space expanding? Is spacetime expanding?
Each solution of Einstein's equation describes a possible geometry of spacetime. One important class of solutions was discovered in the 1920's. They are called FLRW solutions (at least by Wikipedia). To find them, you start with the assumption that spacetime can be sliced into a one-parameter family (with time being the parameter) of 3-dimensional spaces S
t ("spacelike hypersurfaces") that you can think of as "space, at time t". You also assume that each of these hypersurfaces is homogeneous (translationally invariant) and isotropic (rotationally invariant). (You would have to use a very technical definition of the concepts "homogeneous" and "isotropic").
Our universe is neither. For example, there's a chair under me, but not above me. But if we look at very large regions of space, the distribution of matter is starting to look more and more homogeneous and isotropic. This suggests that some of the FLRW solutions might be good approximate descriptions of the large-scale behavior of the universe.
The geometric properties of the S
t are determined by the geometric properties of spacetime. So each FLRW solution specifies a geometry of space, at each time. That's why it's meaningful to talk about how the geometry changes with time.
Now
all of these solutions have the property that the time parameter t can only be defined for values of t larger than some value which we can choose to be 0, and all of them have the property that as t grows, so does S
t (in one of the three main classes of solutions S
t reaches a maximum size after a while and then starts shrinking). The geometry of any S
t can be described by a formula that's the same for all t, except for a number R(t) called a scale factor. In all of these solutions we have R(t)→0 as t→0.
That last bit is why the claim that the large-scale behavior of the universe can be approximated by a FLRW solution is known as "the big bang theory". The distance in space between any two objects depends on R(t) in a way that means that the distance goes to 0 as t goes to 0.
So it's not spacetime that's expanding. (What would that even mean? Wouldn't we need a second time parameter?) Space is expanding. It makes sense to talk about space because we live in a universe which has a large-scale behavior that can be approximated by a solution of Einstein's equation that includes a natural way to slice spacetime into subspaces that we can think of as "space, at time t".
