(2)6 v vs (1) 12 v, amp hours
  • Thread starter Thread starter Starwatcher16
    Amp
Two 6-volt batteries in series typically provide greater amp-hour capacity than a single 12-volt battery due to the total capacity being higher when both batteries are combined. Assuming equal total mass, battery technology, and manufacturing design, the storage capacity remains consistent. Practical factors, such as improved heat dissipation in smaller batteries, may contribute to performance differences, but these are generally negligible. Any significant discrepancies in capacity are likely attributed to variations in battery technology or design parameters.
  • Understanding of battery chemistry and technology
  • Knowledge of amp-hour ratings and capacity measurement
  • Familiarity with series vs. parallel battery configurations
  • Basic principles of heat dissipation in electrical systems
  • Research battery technologies, focusing on lead-acid vs. lithium-ion
  • Learn about series and parallel configurations in battery systems
  • Explore the impact of heat dissipation on battery performance
  • Investigate amp-hour ratings and how they are calculated
Electronics enthusiasts, battery engineers, and anyone involved in designing or optimizing battery systems for performance and capacity.
Starwatcher16
Why do two 6 volt batteries in series usually have more amphours then a single 12 volt battery?
I can't say as I've noticed this myself, but it seems likely that the probable answer--assuming your premise is correct--is that the total capacity of the two 6-V batteries is greater than that of the 12-V one.
All else being equal (total battery mass, not counting packaging, of two 6V batteries being the same as the one 12V, same battery technology, same manufacturing design of cells, etc.) there is no reason the storage capacity would be different. There might be some subtle practical reasons that make them slightly different, like heat dissipation being a little better with two smaller batteries than one big battery, but it wouldn't be a notable difference. If you have an example of a notable difference, then I would strongly suspect its a different technology, notably different design parameters, etc..
  • · Replies 22 ·
