Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Set Theory, Logic, Probability, Statistics
Reply
image Uncorrelated Vs. Independent variables Share It Thread Tools Search this Thread image
Old Jun29-09, 03:59 PM       Last edited by musicgold; Jun29-09 at 04:05 PM..            #1
musicgold
musicgold is Offline:
Hi,
I am confused with respect to these two terms. In a book on regression analysis, I read the following statements.
1. For two normally distributed variables, zero covariance / correlation means independence of the two variables.
2. With the normality assumption, the following equation means that LaTeX Code:  \\mu_i   and LaTeX Code:  \\mu_j   are NOT ONLY uncorrelated BUT ALSO independently distributed.
LaTeX Code:  \\left  \\mu_i  -      N (0, \\sigma^2  \\right)
Not able to get the wiggly line (~) after ui
I am trying to understand if it is possible to have two variables that are
(a) uncorrelated, and not-independent.
(b) uncorrelated and independent
(c) correlated and not-independent
(d) correlated and independent
I would appreciate it if you could explain each type with one example.
Thanks
MG.
Old Jun29-09, 07:44 PM                  #2
statdad
statdad is Offline:
Recognitions:
Homework Helper Homework Helper
Re: Uncorrelated Vs. Independent variables
If the variables are normally distributed, then correlation is zero if and only if they are independent. (By the way, instead of not-independent you should say dependent .
In general, if LaTeX Code:  X, Y  are independent, their correlation is zero, since
LaTeX Code: <BR>E[(X-\\mu_X)(Y-\\mu_Y)] = E[X-\\mu_X] \\cdot E[Y - \\mu_Y] = 0<BR>
so the correlation will be zero.
For uncorrelated but dependent, consider this somewhat classic example. Assume LaTeX Code:  X  has a standard normal distribution, let LaTeX Code:  W  be independent of LaTeX Code:  X  and LaTeX Code:  P(W=1) = 1/2 = P(W = -1)  . Set
LaTeX Code:  Y = W X <BR>
With a little work you can find that
a) LaTeX Code:  Y  and LaTeX Code:  X  are not correlated
b) LaTeX Code:  Y  has a standard normal distribution (calculate LaTeX Code:  P(Y \\le y) = E[P(Y \\le y \\mid W)] =E[P(X \\le y \\mid W)]  , and use both the definition of W and the fact that W, X are independent
For correlated and dependent - look at any multivariate normal distribution with non-zero correlations.
Correlated and independent. Let LaTeX Code:  X  be uniformly distributed on LaTeX Code:  [-1, 1]  and let LaTeX Code:  Y = X^2  .
These two variables are not independent, since LaTeX Code:  Y  is determined by LaTeX Code:  X  , but they are uncorrelated.
c) LaTeX Code:  X  and LaTeX Code:  Y  are dependent.
Old Jun30-09, 09:33 AM                  #3
g_edgar
g_edgar is Offline:
Summary ... (d) is impossible. If X and Y are independent, then X and Y are uncorrelated.
The other three are all possible.
However, when the RVs are normal, (a) is also impossible. For normal random variables X and Y, we have: X and Y are independent if and only if X and Y are uncorrelated.
Old Jun30-09, 04:57 PM                  #4
musicgold
statdad and g_edgar,
Thanks.
I thought the term 'independent' here was the opposite of 'joint', as in 'jointly distributed'.
Also, in terms of examples, I was looking for more simple explanations. For example, can we say
the Height and Weight variables for a certain population are correlated but independent?
I found some discussion at the end of this web page, but it is not very clear to me.
Thanks,
MG.
Old Jun30-09, 05:06 PM                  #5
g_edgar
g_edgar is Offline:
I would not expect them to be independent, since taller people tend to weigh more than shorter people.
Old Jun30-09, 05:28 PM                  #6
statdad
statdad is Offline:
Recognitions:
Some return comments.
Thanks.
No, variables that are jointly distributed may or may not be independent.
No - if you take look at a group of people, and measure (say) each person's height and weight, those measured variables will be correlated - as another says, taller people tend to weigh more, but the more central point is that the measurements are taken from the same person.
Those are good notes, but seem to be (may be - I'm not sure of your mathematical background) more advanced than your current investigations.
Old Jun30-09, 05:49 PM                  #7
gel
gel's Avatar
gel is Offline:
Recognitions:
PF Contributor PF Contributor
No, that's not right. It is not necessary for two uncorrelated and normal variables to be independent. I added a counterexample myself to planetmath website a while ago, here. Are you sure that your book doesn't add an extra requirement that they are "joint normal"? (which is more than just saying that they are normal.)
Edit: I see statdad's example also showed this, but his post started with "If the variables are normally distributed, then correlation is zero if and only if they are independent." which is wrong, unless by 'normally distributed' he meant 'joint normal'.
Old Jul2-09, 05:00 PM                  #8
musicgold
Statdad and gel,
Thanks a lot. I think I will do more reading on this topic and come back with my questions, if any.
MG.
image image
Reply
Thread Tools
Similar Threads for: Uncorrelated Vs. Independent variables
Thread Thread Starter Forum Replies Last Post
independent random variables max and min Proggy99 Calculus & Beyond 4 Apr7-09 03:40 PM
Independent and Dependent Variables ditto_299 Other Sciences 1 Feb2-09 06:30 PM
Complex conjugate variables as independent variables in polynomial equations dm368 Linear & Abstract Algebra 0 Sep26-08 02:46 AM
Change of independent variables problem Coffeepower Calculus & Beyond 4 Sep18-07 02:56 PM
independent random variables WY Introductory Physics 3 Sep3-05 09:28 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
