Depth of a Pit Based on Time Delay of Sound from Falling Rock
  • Thread starter Thread starter RoyalCat
The discussion focuses on deriving the depth of a pit based on the time delay of sound from a falling rock. The formula established is H = \frac{(\sqrt{V^{2}+2gVT}-V)^{2}}{2g}, where H represents the depth, V is the speed of sound, g is the acceleration due to gravity, and T is the total time taken for the rock to fall and the sound to travel back. The participants confirm that the algebraic manipulation leading to this formula is correct, and suggest methods for verifying the solution through expansion and working backwards from the established formula.
  • Understanding of kinematic equations
  • Knowledge of basic algebra and quadratic equations
  • Familiarity with the concepts of speed, time, and distance
  • Basic principles of physics related to free fall and sound propagation
  • Study the derivation of kinematic equations in physics
  • Learn about quadratic equations and their applications in physics
  • Explore the principles of sound propagation in different mediums
  • Investigate the effects of gravity on falling objects in various scenarios
Students studying physics, educators teaching kinematics, and anyone interested in the mathematical modeling of motion and sound. This discussion is particularly beneficial for those tackling problems involving free fall and sound delay.
RoyalCat
A rock is dropped down a deep pit. The sound of its impact with the floor is heard after T seconds.
The speed of sound is a given, V.
Prove that the depth of the pit is:
[tex]H=\frac{(\sqrt{V^{2}+2gVT}-V)^{2}}{2g}[/tex]
Kinematic equations.
T is the time it takes for two motions to transpire. The first is the stone falling, [tex]t_1[/tex]. The second, is the sound traveling back up, [tex]t_2[/tex].
[tex]T=t_1+t_2[/tex]
For the falling rock:
[tex]y(t)=H-\frac{g}{2}t^{2}[/tex]
[tex]y(t_1)=0[/tex]
[tex]\frac{g}{2}t_1^{2}=H[/tex]
[tex]t_1=\sqrt{\frac{2H}{g}}[/tex]
For the wave of sound:
[tex]y(t)=Vt[/tex]
[tex]y(t_2)=H[/tex]
[tex]Vt_2=H[/tex]
[tex]t_2=\frac{H}{V}[/tex]
[tex]T=\sqrt{\frac{2H}{g}}+\frac{H}{V}[/tex]
Now all that remains, so it would seem, is to extract H, since we have one equation with just one variable, since T,V and g are all given.
[tex]T-\frac{H}{V}=\sqrt{\frac{2H}{g}}[/tex]
[tex]T^{2}-\frac{2TH}{V}+\frac{H^{2}}{V^{2}}=\frac{2H}{g}[/tex]
[tex]\frac{T^{2}V^{2}g}{V^{2}g}-\frac{2TVgH}{V^{2}g}+\frac{gH^{2}}{gV^{2}}=\frac{2V^{2}H}{gV^{2}}[/tex]
[tex]T^{2}V^{2}g-2TVgH+gH^{2}=2V^{2}H[/tex]
[tex]gH^{2}-(2TVg+2V^{2})H+T^{2}V^{2}g=0[/tex]
[tex]H=\frac{2TVg+2V^{2}+\sqrt{(2TVg+2V^{2})^{2}-4T^{2}V^{2}g^{2}}}{2g}[/tex]
And from here, the algebraic manipulation eludes me. Have I made a mistake somewhere along the way? I was thinking about completing the square or some other nonsense, but the coefficient of 2 before [tex]V^{2}[/tex] looks like it's going to be a problem.
If you set a pseudo-variable
x = H1/2
You can say that you have a quadratic in x ...
1/V*x2 + √(2/g) * x - T = 0
Then square the resulting solution.
I haven't done it, but I'd say a cursory inspection suggests a similar result to where you are.
No you haven't made a mistake, and you've got just a few small algebraic steps left. Try expanding the [itex](2TVg + 2V^2)^2[/itex] under the square root.
If you're still stuck, try working backwards: starting from the solution you're supposed to end up with, expand [itex](\sqrt{V^2 + 2gVT} - V)^2[/itex] and see if you can convince yourself that it's the same as what you got.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 21 ·
