Connecting Relays to Circuit Boards: Step-by-Step Guide
  • Thread starter Thread starter ahmedahmed
    Circuit
The discussion revolves around connecting relays to circuit boards, specifically focusing on understanding the various connection terminals of different relay types. Participants seek clarification on specific relay models and their terminal configurations, including requests for visual aids.
  • Homework-related
  • Ahmed Hassan requests images and detailed information about relay connections, particularly for relays with more than four terminals.
  • Some participants suggest that Ahmed should refer to the datasheet of the specific relay model for accurate connection information.
  • There is a note that terminal numbering can vary by manufacturer and relay type (e.g., SPST, SPDT, DPDT), indicating a lack of standardization.
  • Questions arise about whether Ahmed has a specific relay model or application in mind, as this information is crucial for providing accurate assistance.
  • One participant emphasizes the need for a relevant relay catalog and diagrams to understand the terminal connections better.
Participants do not reach a consensus on the specific relay model or the exact information needed. Multiple views on how to approach the question remain, with some suggesting the use of datasheets while others seek more detailed visual aids.
There are limitations regarding the lack of specific model numbers and the variability in terminal numbering schemes across different manufacturers, which complicates the discussion.
ahmedahmed
Hi everybody
I need the connection for relay in boards
Also try to put images
Thanks
Best regards
Ahmed Hassan
Of course this is a nother question
There is a type of relay with more than 4 connections on it.
you can see connection number as (1,2,3, . . . A1, A2) and there is more than this numbers
I need picture with all connection number and what is that for
Thanks
Best Regards
Ahmed Hassan
Thanks
Best Regards
Ahmed Hassan
Use the company name and part number that are printed on the relay to find the datasheet for it online. That should give you the connection information.
We need a specific model number, or at the very least the type of relay and the maufacturer. There is no standard terminal numbering scheme; each manufacturer uses his own and even then there are going to be differences depending on whether the relay is an SPST, SPDT, DPDT or something else.
I'm not sure what you're asking anyway. Either you already have a relay and need the datasheet, in which case Google should help you, or you have a particular application that you need to determine which type of relay to use, in which case, we need that information. Where are you getting these terminal numbers from?
you must refer to relevant relay catalogue and note to similar attached diagram.
  • · Replies 31 ·
  • · Replies 25 ·
13K
  • · Replies 25 ·
