Sawyer-Tower Circuit Hysteresis: Connections to Oscilloscope
  • Thread starter Thread starter NAP2626
    Circuit
The discussion revolves around the reconstruction of an experiment to measure the hysteresis loop in a Sawyer-Tower Circuit, focusing on the connections to an oscilloscope and the use of a breadboard for circuit assembly. Participants seek clarification on specific connections and configurations necessary for accurate measurements.
  • Homework-related
  • One participant inquires about the final connection to the oscilloscope after the linear capacitor, questioning whether it is a ground connection.
  • Another participant suggests that the connection is likely a chassis ground from the oscilloscope's front panel.
  • A participant references the oscilloscope manual to support their claim about the ground connection.
  • There is a concern raised about the configuration of components on a breadboard, specifically whether placing components on a power strip would short out the circuit.
  • Participants discuss the importance of using the correct holes on the breadboard for making connections, emphasizing the isolation of vertical rows of holes.
  • One participant shares their experience of successfully constructing the circuit after obtaining the same breadboard as used in the lab report, although they report mixed results in their experiments.
  • Another participant expresses uncertainty about the measurements obtained when using an AFM tip with the ferroelectric capacitor, noting that the hysteresis loop remained even when the tip was raised.
Participants do not reach a consensus on the correct configuration for the breadboard connections, and there are mixed opinions regarding the reliability of the experimental results. Uncertainty remains about the measurements and the behavior of the hysteresis loop.
Participants express confusion regarding the connections on the oscilloscope and the breadboard setup, indicating potential limitations in their understanding of circuit assembly and measurement techniques.
This discussion may be useful for students and hobbyists interested in electronics, particularly those working with hysteresis measurements in circuits and using oscilloscopes for data acquisition.
NAP2626
Hey All,
I am trying to recontruct an experiment for measuring a hysteresis loop in a Sawyer-Tower Circuit. It is a simple experiment and I attached a pdf of an undergrad lab for it.
My question is what are the connections to the Oscilloscope. In the picture you have channel 2 and channel 1 connected to segements within the circuit, but what is the final connection to after the linear capacitor? It appears to be going to the scope, but is it a ground or something? I am referring to figure 10 in the attached experiment.
Following the linear capacitor there is a red line connected to the scope but I am not sure what is connected to on the scope. There is also a black line across from it that is the ground to the function generator. Thanks for any help, and also excuse my misunderstanding/mistating of anything. I am not an EE.
I think they ran out of black banana-to-EZhook cables. That looks to be a chassis ground connection out of a banana jack on the 'scope front panel.
Yeah, here it is. On page 2-2 of the TDS 360 oscilloscope manual:
http://www.google.com/url?q=http://www-micrel.deis.unibo.it/PDF/tds340user.pdf&ei=T45KSuGqPIPYM-iGuakO&sa=X&oi=spellmeleon_result&resnum=1&ct=result&usg=AFQjCNHl3AmEPQ0Cws7sUUMSoXC7GdiVNw
It's a banana female connector to chassis ground.
Hey thanks Beckman!
Ok last question. I could not find the exact same breadbox electronic circuit board. I was able to get a simple one from radioshack and I was wondering if this will work.
I tried to duplicate the exact circuit from the earlier pdf. I attached a sketch of the circuit I made. The main gold stripe is the copper that is the power strip and it seems that all holes for this stripe are connected in series and I tried to be all elements on this strip, but also to the side, in sockets that are not in the series. Will this be ok?? Or should I have it all in series like the circuit below it (in sketch??)
I want to duplicate the experiment as close as possible, but can't get my hands on the exact same circuits. Once again thanks for all the help
If the strip down the middle is all connected, won't it short out all the components?
Wow quick response.I thought that by having it on that strip would make it all in series. Should I connect it sockets that are connect by the strip?
I am a novice when it comes to using this boards/ making this sawyer-tower circuit.
I can do this but then I guess how are the connections getting to the wires and capacitors. This was confusing to me as well when looking at the pictures in the lab
In the picture in the document, the vertical rows of 6 holes are connected together, and isolated from all the other vertical rows. So if you put the end of one component in one hole, and the end of another component or wire in a hole either above or below it (in the same vertical group of 6 holes), that makes contact between them.
So ou the board you bought, there should be some number of holes that are connected together, like 4-5 of them typically, in a group. Use each of these groups to help you make each junction connection.
Can you post a picture of your board, and then another picture with the components on it in the right positions (but not soldered yet)?
Berkeman, thanks for all the help.
I attached a picture of the board I got from Radioshack.
The ferroeletric cap. and linear capactior look exactly the same as the picture from the lab report. We made the ferroelectric cap. which is why we are testing to see if it will work. I bought several linear caps from radio shack ranging from 100pF to 100 microF. But more or less they look exactly the same as the one pictured.
The loops for the connections I made from desheathed wires and the wires I used are 22 guage.
Any suggestions?
Thanks again man you are the best
Any suggestions?
The attachment didn't seem to work. Try again? (BTW -- we're all glad to help)
Oop sorry. Here it is again
It's a little hard to tell (pic is a little small), but it looks like there are groups of 3 holes connected together. Those would be the ones you would use to make your component-to-component connections. The horizontal rows of connected holes across the middle of the board are for bussing power and ground, to make those available for strapping to any of the groups of 3 holes.
OK so my labmate was holding out!
He had the same exact board and I was able to construct the circuit just like the lab.
So far results are mixed it works and then it doesnt.
Berkeman, do you know of any sawyer-tower based circuits that would work for studying PZT capacitors? We want to start studying small (micron level) capacitors using an AFM tip to make contact with the ferroelectric capacitor and then connected it to the remaining sawyer tower circuit.
We attempted it today and once again it seemed to work and other times no so much. Actually it was uncertain if it was working very well. We were getting beauitful results, but when we raised the AFM tip up the current didnt die off and the hysteresis loop remained which made us skeptical that we were correctly measuring it.
  • · Replies 27 ·
  • · Replies 17 ·
