Neutral-earth harmonic resonance
The discussion centers on the necessity of measuring neutral-earth harmonics during the design stage of variable speed drives (VSDs) connected to three transformers in parallel. It is established that the neutral path in power systems can carry third harmonic currents, which may disrupt communication systems. A recommended solution is to utilize delta connections in converter transformers to trap these harmonics effectively. This approach can be predicted and is crucial for maintaining system integrity.
  • Understanding of harmonic currents in power systems
  • Knowledge of variable speed drives (VSDs)
  • Familiarity with transformer connections, specifically delta connections
  • Basic principles of electrical system analysis
  • Research methods for measuring neutral-earth harmonics in power systems
  • Explore the design and implementation of delta connections in transformer systems
  • Learn about the impact of third harmonic currents on communication systems
  • Investigate predictive analysis techniques for harmonic distortion in electrical systems
Electrical engineers, power system designers, and professionals involved in the analysis and optimization of variable speed drive systems.
luc4van
When carrying out a system analysis During design stage (Variable speed drives connected to 3 transformers in parallel) is it a normal practise to check/measure neutral - Earth harmonics, can this be predicted?
The neutral path of power system is a suitable path for flowing of 3th harmonic current which can interfere to communication systems. One of known way for elimination this harmful effect is the trapping of 3th and other its multiplier harmonic in delta connection of converter transformers which can be predicted in mentioned VSD system.
For similar discussion you can refer to Transformer riddle No.5 from http://electrical-riddles.com
  • · Replies 83 ·
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 41 ·
