Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Special & General Relativity
Reply
image gravimagetism motor! Share It Thread Tools Search this Thread image
Old Jul2-09, 11:30 AM                  #1
meemoe_uk
meemoe_uk is Offline:
I was thinking about gravimagnetism, in particular the curious comparisons to electromagnetic results. In my physics studies on electromagnetism, I remember one exercise asking to describe the setup for generators and motors, i.e. conducting coil and magnet. One of the results to be obtained was : which way does the coil force the magnet as it enters the coil? The movement of the magnet through the coil is opposed by the induced magnetism of the coil. OK, but then the exercise asked to prove that if it were the other way, coil attracted the magnet through the coil, then it would be a violation of the 1st law of themodyanics. i.e. a magnet on a closed track passing through the coil would build up KE indefinately. OK, but this proof would also infer the equivalent gravimagnetism setup would break the FLoT. Since this isn't allowed, some other physics must happen to stop the violation. What is it I wonder?
wiki mentions that "if two wheels are spun on a common axis, the mutual gravitational attraction between the two wheels arguably ought to be greater if they spin in opposite directions than in the same direction."
Wiki doesn't say that due to that result of physics ( I can't remember what it's called, someone tell me, I'll call it the minimal potential law ) entities will naturally 'fall' towards their lowest potential energy states, therefore as the velocity of rotation of the wheels increases, the attraction between the wheels will become stronger and amplify the gravimagnetic effect, a postive feedback loop.
In protest someone might point out that the lowest energy state of the wheels is zero velocity, so the minimal potential law would suggest the wheels would come to stop ( by friction ) not speed up. However theorectic science has for a long while had gravity as a negative force, gravity force has a minus sign in equations, and the convention isn't just arbitary. If the wheels spun fast enough, gravimagetism would present a lower energy state than zero velocity, and the wheels would 'fall' towards this feedback loop.
In practice, the most likely candidates for gravimagnetism are spinning quasars and neutron stars.
Anyway, what are the 'official' theorectics on how the electric motor gravity equivalent set up doesn't break the FLoT?
I was thinking since relativity seems to slow things down in there internal workings, maybe this is where the energy is balanced out?
Old Jul2-09, 05:28 PM                  #2
Jonathan Scott
Jonathan Scott is Offline:
Recognitions:
PF Contributor PF Contributor
Re: gravimagetism motor!
I'm having some difficulty following what you're saying. We know by Lenz's Law that an induced current opposes the motion which induces it. I'm guessing you're suggesting that since like charges repel in electrostatics but all masses attract by gravity, there's some sort of sign change which might mean that a gravitomagnetic field would strengthen the motion which induces it. That seems unlikely to me; I'd guess that since the induced field and motion both change sign, we'd still be in the same position, although I don't have a clear enough picture of what you have in mind to make a definite statement.
Apart from that, the similarities between electromagnetism and gravity are rather limited; as soon as one gets into situations where the gravitomagnetic field is relevant, the flat space approximation means that the analogy does not hold accurately in conventional Euclidean background coordinate systems for example as used to describe orbits. The lack of an "opposite charge" in gravity also means that various things available in electromagnetism, such as a purely magnetic field over a finite volume of space, are not possible in gravity.
Old Jul3-09, 11:33 AM                  #3
meemoe_uk
>I'm guessing...there's some sort of sign change which might mean that a gravitomagnetic field would strengthen the motion which induces it.
Good guess.
I'd like to test you, too much of the time on these forums the reason why people don't understand is because they aren't qualified to know, not because the question poster is being vague.
Looks like you haven't studied gravitomagnetism much. These are the base questions which should ignite interest, if not gravitomagnetism isn't for you. The picture is simple.
Give answers in terms of the relativistic effects which cause the phenomena.
1. A closed track on which a magnet travels freely around on. A conductor coil through which the magnet travels through on some part of the track. The coil opposes the motion of the magnet as it travels through the coil.
Why?
2. Two conductors wires side by side of indefinate length. When an electric current travels through each wire in the same direction the wires attract each other.
Why?
3. Now ask yourself, what is the gravity equivalent to these setups?
Next some minor details...
What makes you think flat space is so crucial to orbits? Things orbit neutron stars you know. Gravity probe B has been orbiting Earth happily for years measuring the gravitomagnetic aspect of Earth.
I don't see this is true, nor ,if it is, why it's relavent. 1st of all, all fields are infinite according to standard model, including the strong nuclear force.
Old Jul3-09, 01:10 PM       Last edited by Jonathan Scott; Jul3-09 at 01:12 PM.. Reason: Removed confusing "other way" about rotation            #4
Jonathan Scott
Recognitions:
Good guess.
Why?
Why?
A more polite approach might encourage better answers.
The reason I don't have a clear picture of what you are suggesting is that there is simply no gravitational equivalent of a "magnet", with a gravimagnetic field but no static gravitational field. That is because there is only one sign of gravitational "charge" so it is not possible to construct the equivalent of electric currents in where one charge flows past the opposite charge in an overall uncharged medium.
Gravitomagnetism is normally an extremely tiny rotational effect superimposed on the normal static gravitational field. Within a gravitomagnetic field, an observer feels as if he is rotating even when he is not doing so relative to the distant stars, or feels as if he not rotating when he is actually rotating with the same angular velocity as that of the gravitomagnetic field (apart from any factors of 2 which depends on the conventions assumed for specifying the gravitomagnetic field strength).
You can in theory create a "purely gravitomagnetic" field by balancing the pull of gravitational sources in different directions, for example at the axis of a rotating ring and inside a rotating sphere, but such a field is of very limited extent.
The point about orbits is that if you want to calculate them accurately enough to need to take into account gravitomagnetic effects, you also need to take into account the curvature of space, as this has effects of similar magnitude. You can use a gravitomagnetic model on a small scale to describe approximately how gravitational effects vary locally under Special Relativity transformations, such as throwing an object a short distance on a very dense planet, but in that case your calculations are relative to the space of a local observer, which would appear to be slightly curved relative to background coordinates suitable for describing a complete orbit.
Old Jul7-09, 12:41 PM                  #5
meemoe_uk
Likewise, directly answering the questions put to you might encourage a thankful reply. And don't use the 'no gravitomagnetism' excuse either ( see below ), given over 60 hours, you've failed to answer the elementary questions on electro-magnetism.
Oh dear. Sorry you think that. What where Hawking, Penrose, Clark, Tucker, Heaviside, Mashhoon and others thinking of when they used the term gravitomagnetism if not a gravitional analogy to magnetism? They'd be interested in your reply.
This explains the communication difficulty we are having.
Any mass that has angular momentum is a 'gravity magnet'.
>Gravitomagnetism is normally an extremely tiny rotational effect superimposed on the normal static gravitational field....
Guess what... I already know! I'm interested in gravitomangetism. I've covered the basics already.
>The point about orbits is that if you want to calculate them accurately...
10/10 on following up digressions. 0/10 for answering questions put to you.
Since you can't answer standard questions on relativity & electromagnetism, I doubt I need any more of your posts.
Thanks, I'll try reading Penrose, he talks about special ways of extracting energy from blackholes.
P.S.
>...is simply no gravitational equivalent of a "magnet", with a gravimagnetic field but no static gravitational field.
Likewise, there is no magnetic field without a moving electric field. In a permanant magnet, the moving electric field is a net angular momentum of the elecrtrons in the constituent atoms. Usually the atoms are aligned. Magnetic atoms slightly resemble gyroscopes in the key aspect.
Old Jul7-09, 02:17 PM                  #6
Jonathan Scott
Recognitions:
Maxwell's equations and Lenz's law are available in any standard text book (and online too) and if you don't know the answers you shouldn't be trying to understand gravitomagnetism.
Are you really unable to understand my main point? I didn't say there is no gravitomagnetism; I said that there is no gravitational equivalent of a conventional "magnet", that is something with a magnetic field but no electric field.
Also, contrary to what you said in your PS, there isn't necessarily any electric field associated with a magnet. Your concept of a "moving electric field" or even a "moving magnetic field" is not physical; overall the field has magnetic and electric components; the field of a moving charge includes a magnetic part as well as an electric part, and the field of a moving magnet includes an electric part as well as a magnetic part.
If you really want to understand gravitomagnetism, I found the book "Gravitation and Inertia" by Ciufolini and Wheeler very helpful, especially chapter 6 "The Gravitomagnetic Field".
Old Jul7-09, 04:34 PM                  #7
OB 50
OB 50 is Offline:
How is your scenario of two counter-rotating wheels any different than one stationary wheel and one rotating wheel? Where is the big mystery? Are you surprised that any time a single wheel is set in motion relative to a stationary object, it doesn't perpetually increase it's rotational velocity to infinity?
Old Jul9-09, 01:18 PM       Last edited by ZapperZ; Jul10-09 at 06:18 PM.. Reason: Removed unnecessary comments            #8
meemoe_uk
OBy...
It's not my scenario, that's the one from wiki. I'd say the difference is that while rotational energy can be relative(dependant on the view of the rest of the universe), it is in most respects absolute(independant of the rest of the universe). But that doesn't matter much to key behaviours I was looking at.
For me it's why you're having to ask where the 'big mystery' is, as you call it, I think your refering to my initial question.
No. And if you'd read my previous posts you'd know I think in most cases gravi-magnetic forces aren't relavent.
Scotty...
I know the point your making and I think it's glossing over the important detail. There is an electric field associated with the magnetic field of a permanent magnet, but it is 'hidden'. *Do you know where it is? hint - I've already told you.
What are you talking about now? Could you elaborate on this?
Old Jul9-09, 02:44 PM                  #9
Jonathan Scott
Recognitions:
I'll give you one more try to do the questions I've set you ( then I'll give the answers ). Read up on them, that way some good will have come from this thread. Otherwise I'm reporting you to the administrators for not being qualified to do your job!
I don't know how you think these forums work, but I'm not any sort of "member of staff", nor even a mentor! Most of the replies you will get here are just from people like myself who are trying to help other people understand physics, and if you don't show some appreciation for that you're not likely to get much help at all. I certainly can't be bothered to waste time trying to explain how Lenz's law works, especially as there's a perfectly good Wikipedia entry on the subject.
The idea of "moving" electric or magnetic fields is a common misconception. Obviously fields can change, and the place at which a field has a particular value can move, but all the properties of the electromagnetic field at an arbitrary point in space and time are described by the electric and magnetic field, without any reference to velocities. The fields in any other frame of reference can be determined by the appropriate transformations, where a moving charge gives rise to a magnetic component and a moving magnet gives rise to an electric component.
Of course a real magnet can be considered to be built up at the microscopic level of atoms containing charge, including electrons moving around orbitals and even charge distributions moving around within nuclei. However, a magnet can easily be electrically neutral overall, so that it has no macroscopic electric field. As there is only one mass "charge", the gravitational equivalent is not possible.
Old Jul9-09, 09:01 PM                  #10
pallidin
pallidin is Offline:
Ah, "frame-dragging"!
What an interesting effect. My understanding is that it is detectable only under the circumstances of very massive rotating objects, such as our own planet.
Old Jul22-09, 06:58 AM                  #11
meemoe_uk
Here's the answers to the questions I set.
Why?
Answer: Unlike a non magnetic atom where the electron momentums roughly cancel out, the constituent atoms in a magnet have electron orbits that have a significant net angular momentum, and so a net angular coulomb charge momentum traveling at relativistic speed, at which space contraction is a significant effect. The stationary electrons in the conductor coil percieves the fast moving electrons in the magnet to be space contracted, while the protons in the magnet are not percieved to be space contracted. Thus the magnet appears to have a higher density of electrons than protons, thus a net negative coulomb charge, thus electrons in the coil with be repulsed by and oppose the magnet. This effect depends on the magnet's charateristic 'organised' polarity of constituent atoms. The resisting force of the coil to the magnet is the force necessary to knock electrons out of their loose bonding to the coil's conductor atoms.
Why?
Answer: The current in either one of the wires is composed of electrons traveling at a high speed where relativistic effects are considerable. Consider the point of view of one of these electrons. From it's point of view, the electrons in the other wire are traveling in the same direction and at roughly the same speed, so they are roughly at rest wrt each other. The protons in the other wire are stationary. Wrt to the electrons, they are moving at a high speed, and so relativistic effects are considerable. The important effect is relativistic space contraction. The protons are space contracted wrt to the electron, while the electrons in the other wire are not. Thus the electron percieves a higher density of protons to electrons in the other wire, therefore it percieves a net coulomb attraction. This effect applies to all the current-electrons, and also all the protons in the wires. Thus the wires attract.
Answer: For the parallel wires - Two streams of high energy matter pass each other on parralel paths. The high relative speeds of the streams causes space contraction perception for both streams when viewing each other. Thus the streams percieve each other to have higher density, and thus are attracted more.
For the coil and magnet, a gravity equivalent is highly impractical, but many hypothectical situations have been analysed ( see wiki and gravitomagnetism ). Some of the essential aspects, most notably the angular momentum, can be preserved in the following more likely situation. A fast spinning neutron star has a ring of material orbiting fast in the opposite direction to the neutron star's spin. The high relative speeds of the ring and star cause space contraction perception, thus higher density perception thus higher mass perception thus higher gravitational attraction. The higher gravity causes higher accelaration force on both the ring and star, therefore both the ring and star speed up, this constitutes a feedback loop in violation of the FLoT, which ought to be broken by some other physics.
Old Jul22-09, 08:13 AM                  #12
meemoe_uk
ok! This is a good page. Next time someone asks you to describe magnetism and it's relativistic cause, and you don't want to, post this link.
http://en.wikipedia.org/wiki/Lorentz_force
Old Jul22-09, 01:33 PM                  #13
Jonathan Scott
Recognitions:
Here's the answers to the questions I set. ...
You're apparently trying to "explain" the magnetic field in terms of electric fields seen from other points of view. This can work in some cases, but does not provide a useful general explanation.
It is not necessary to involve either microscopic internals or relativistic speeds to explain magnetism. Electrons in wires carrying current typically creep along at very slow average speeds. A single charged particle travelling at high speed gives rise to a magnetic field. Neither of these cases is handled by your description.
The Lorentz force law has nothing at all to do with your way of looking at magnetism, and I don't understand why you think that article is relevant in this case.
Note that if the appropriate notation is used, the electromagnetic field can be represented as a single complex object E+iB and the Lorentz force law (including a time-like part for the rate of change of energy) is trivial, as is transforming to any other frame of reference. An introduction to my own version of this notation, including the Lorentz force law, can be found in my little informal book "Complex Four-Vector Algebra" on the web, which you can easily find in Google. There's now a more widely publicised version of the same algebra known as the "Algebra of Physical Space" which uses slightly different notation; the text book "Electrodynamics: A modern geometric approach" by W Baylis uses this notation throughout.
I've been putting up with your apparent total lack of common courtesy because your original question about gravitomagnetism seemed potentially quite interesting. Are you suggesting that if you have one rotating disk or ring and bring another one near it, you think that gravitomagnetism would mean that the change in field would cause the second one to start spinning in the same direction, which would then apparently induce an INCREASE in the spin of the first one, apparently getting energy from nowhere? If so, I'm sure that doesn't happen, and if the faster disk caused the other one to speed up, then it would obviously get slowed down by that, but I'd agree that there's a bit of a puzzle there in the analogy with electromagnetism.
Old Jul23-09, 11:58 AM                  #14
meemoe_uk
We'll have to differ.
Ohno, not that old trick. At least you got the word 'average' in to make what you say techincally correct. See Archie Gore's well presented but flawed analysis of current flow to reach your conclusion.
http://www.geocities.com/archisgore/...ectricity.html
What he fails to note is, as a percentage, very few electrons in a conductor are knocked out of their atoms. When they do, they don't get far before they are captured by another atom, then they sit there for a long time.
He assumes that, whenever a voltage is applied, effectively every single atom in the conductor releases it's free electrons! In the calculations this brings the electron speed down by many orders of magnitude.
Any others in the slow electron camp here?
I'm giving up for now. You've got the whole forums staff backing you up, and I'm being stung at every post by them. If you want to see my unedited posts you'll have to PM me.
Old Jul23-09, 12:08 PM                  #15
Hootenanny
Hootenanny's Avatar
Hootenanny is Offline:
Recognitions:
Homework Helper Homework Helper
Retired Staff Retired Staff
If you read the messages that have been sent to you, I think you'll find that it's your attitude that we object to and we aren't actually taking sides in the debate.
Old Jul23-09, 01:54 PM                  #16
Jonathan Scott
Recognitions:
I'm definitely in the non-relativistic electron camp.
You didn't answer my last question. Is the situation I described with the rotating rings the specific case in which you are interested?
If so, I don't have a calculated solution (and I expect it would be very tricky), and I'm sure that since curved space has a significant effect here, the similarities with electromagnetism are not sufficiently accurate to be a useful guide. However, some time ago I investigated what happens when you apply a Lorentz transformation to the classic system involving one body moving around another, and I found that for non-relativistic speeds the effective "magnetic" force between them is related to the relative velocity difference between the bodies. I think this suggests the plausible conclusion that the frame-dragging effect speeds up the slower ring but slows down the faster one, preserving energy and angular momentum overall.
image image
Reply
Thread Tools
Similar Threads for: gravimagetism motor!
Thread Thread Starter Forum Replies Last Post
dc motor 9876098 Electrical Engineering 2 Mar8-09 01:55 AM
1 RPM Motor help. Cremer Mechanical Engineering 18 Feb14-09 08:14 PM
DC Motor OutCell Mechanical Engineering 3 Jun5-07 11:05 AM
Help 3ph motor wolram Electrical Engineering 4 Aug12-06 05:56 AM
New motor lengould Electrical Engineering 1 Dec22-04 01:25 PM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
