Automated mouse pressing device
  • Thread starter Thread starter exoticdisease
    Automated Device
The discussion revolves around the creation of an automated device to press a computer mouse button at regular intervals, specifically every 15 minutes. Participants explore various mechanical and electronic solutions, as well as software alternatives, while addressing the feasibility and implications of each approach.
  • Rob seeks a mechanical solution to automate mouse button pressing, inspired by a scene from The Simpsons.
  • Exoticdisease suggests using a timing device plugged into the mouse port as a potential solution.
  • Several participants mention available software options for automating mouse clicks, including macro recorders.
  • Rob expresses a preference for a hardware solution over software, despite acknowledging the utility of macro recorders for other tasks.
  • Concerns are raised about the safety and practicality of using a timer device, with a suggestion to consult someone knowledgeable in electronics for guidance.
  • Participants discuss the possibility of shorting the button leads of an existing mouse as a straightforward method to achieve the desired automation.
  • Fleem and Topher925 propose a more technical approach involving soldering wires to the mouse's PCB and using a transistor or relay to automate the pressing mechanism.
  • Rob requests clarification on technical terms and instructions for modifying the mouse and obtaining necessary components.
  • Rob inquires about the potential for third-party detection when using macros on web pages, expressing concern about privacy and security implications.
Participants generally agree on the need for a mechanical solution, but there are multiple competing views on the best approach, including both hardware and software options. The discussion remains unresolved regarding the specifics of implementation and the implications of using macros.
Participants express varying levels of technical knowledge, with some needing more detailed instructions on electronics and component sourcing. The discussion includes assumptions about the capabilities of USB devices and the potential risks associated with using macros.
This discussion may be useful for individuals interested in DIY electronics, automation projects, or those exploring alternatives to software-based solutions for repetitive tasks.
exoticdisease
I'm doing something that requires pressing my computer's mouse button once every 15 minutes so I'm trying to find something that will automatically do it for me whether I'm there or not. If anyone has seen that Simpsons episode where Homer uses the drinking bird to press the "Y" button on his keyboard to speed up his work, that's kinda what I want, except for a mouse button.
Basically, I'm going to attach the mouse to my desk so it won't move when pressed and then I want something to press it every 15 minutes or more (as long as it's as often as 15 minutes, it doesn't matter how much more often it is). Any ideas/suggestions would be welcome. For example, does anyone have a drinking bird that they could test it out on a mouse for me?
Thank you very much for your help
Rob
Welcome to PF, Exoticdisease.
Wouldn't it be easier to plug a timing device into the mouse port of your computer? I don't know much about this stuff, but that's the first thought that comes to me.
Yuck!
Those things are for Windows-burners. I thought that Rob had a computer.
I must admit that I am using Windows *shame shame*
Also, I must have something mechanical not software based...though I did have a look at the macro recorder and it's quite good tbh! Might use it for other things, but this must be hardware.
You mentioned a timer danger...could you give me some more details or a link for me to read up about it? It sounds quite reasonable...
Thanks
I'm afraid that I can't. I really don't know much about anything, particularly electronics. It just seems to me that almost anything can be plugged into a USB port. Someone like Chroot can probably hook you up with a design or a commercial timing product.
You don't have to make a USB device. Just short the button leads of an existing mouse.
Ahhhh... Obvious in retrospect, but it never crossed my mind. Good catch.
This is what I was thinking. Just solder to wires to the terminals on the PCB where the mouse button connects and run them to a transistor/relay on a basic stamp that shorts them every 15 minutes or whenever you want.
That sounds very promising...sadly, I don't really have a clue what you're talking about, fleem and Topher925! If you could provide me with some instruction I would be most grateful. To start, what would I have to do to my mouse, what's PCB and where do I get a transistor relay to set on the basic stamp?
Thanks very much :D
Oh and also...is there any way a third party could detect me using a macro ? I'm familiar with macros in Word and Excel, but I've never run one like this...if I run it on a webpage, would it be possible for the page owner to detect me doing it ?
Thanks again!
  • · Replies 19 ·
12K
  • · Replies 41 ·
