Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Linear Factor Rule Share It Thread Tools Search this Thread image
Old Jul3-09, 04:43 AM                  #1
The Anomaly
The Anomaly is Offline:
Linear Factor Rule
I'm studying the Partial Fraction method of integration, and I believe I understand the fundamental idea of it. However, much of it is based on a rule that the book calls the Linear Factor Rule. It is the following:
For each factor of the form (ax+b)m the partial fraction decomposition contains the following sum of m partial fractions:
LaTeX Code: \\frac{A_1}{(ax+b)} + LaTeX Code: \\frac{A_2}{(ax+b)^2} + ... + LaTeX Code: \\frac{A_m}{(ax+b)^m}
I'm assuming that the proof of this is either assumed, or was done in a Precalculus course or something. But could you help me out with proving it? It just doesn't make much sense at this point.
Old Jul3-09, 05:53 AM                  #2
g_edgar
g_edgar is Offline:
Re: Linear Factor Rule
No, the proof that such numerators exist is found only in more advanced courses. But to proceed in integration you do not need that proof. Even if you have not proved that such coefficients exist in all cases, if such coefficients exist (as they always do) in the case you are doing, then you can go ahead with the integration.
Old Jul3-09, 05:55 AM                  #3
The Anomaly
Alright, that makes sense. I just wanted to make sure that I wasn't missing some obvious proof from precalculus.
Thanks for the reply!
EDIT: And for curiosity, when my Calculus book refers to advanced algebra (Not exactly for this example, but for others) are they referring to Precalculus algebra? Or way more advanced stuff that I have not approached yet?
image image
Reply
Thread Tools
Similar Threads for: Linear Factor Rule
Thread Thread Starter Forum Replies Last Post
Utility of Form factor and Crest factor in an AC waverform dE_logics Classical Physics 2 Mar15-09 09:30 AM
Linear statistical model: inference about interaction coefficients, two-factor solar42 Calculus & Beyond 0 Nov26-08 06:50 PM
Using Cramer's rule to solve linear equations with complex coefficients? Noone1982 General Math 3 Dec28-06 02:06 PM
Differential Equations - Linear Factor Proof DoubleMike Calculus & Analysis 13 Feb11-05 07:54 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
