Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > General Math
Reply
image Kinematics question Share It Thread Tools Search this Thread image
Old Jul3-09, 03:08 PM                  #1
fereak
fereak is Offline:
Kinematics question
Hey,
Not sure if this is in the right place, move if necessary.
So, I know about SUVATs, and non-constant acceleration, using Calculus.
I also (basically) understand how to calculate the force of drag on an object.
How could I combine the 2, calculate the final velocity/acceleration of a falling object, taking into account air resistance?
Thanks, my knowledge is limited to AS Level Pure Maths and GCSE Physics, for now. :)
Old Jul3-09, 07:05 PM                  #2
tiny-tim
tiny-tim's Avatar
Homework Helper 2008
tiny-tim is Offline:
Recognitions:
PF Contributor PF Contributor
Homework Helper Homework Helper
Smile Welcome to PF!
Hey fereak ! Welcome to PF!
You'd get an equation something like dv/dt = -kv + c, and just integrate it.
Or do you have something more complicated in mind?
Old Jul3-09, 07:13 PM                  #3
fereak
fereak is Offline:
Re: Welcome to PF!
Where did you get that from? What is k? and c?
Old Jul3-09, 07:21 PM                  #4
tiny-tim
tiny-tim's Avatar
Recognitions:
(k and c are constants)
No … you first … what did you get?
Old Jul4-09, 05:36 AM                  #5
fereak
fereak is Offline:
Re: Kinematics question
Well I know the SUVATs:
and the drag equation:
But, for the drag equation, the velocity must be given. We can calculate that using SUVATs/Calculus but it would surely be affected by the drag, but to work that out I need velocity! And once I know the drag force, how can I apply it to the velocity to see how its affected?
Or am I overcomplicating? Could I just substitute them together?
Old Jul4-09, 01:29 PM                  #6
tiny-tim
tiny-tim's Avatar
Recognitions:
ah … that drag equation has force proportional to v2, so the differential equation would be of the form dv/dt = -kv2 + c …
again, just integrate
Old Jul4-09, 01:59 PM                  #7
fereak
fereak is Offline:
Sorry, but integrate what?
Old Jul4-09, 02:09 PM                  #8
tiny-tim
tiny-tim's Avatar
Recognitions:
Integrate dv/(-kv2 + c) = dt
Old Jul4-09, 02:33 PM                  #9
fereak
fereak is Offline:
Wha? Why??
I'm deeply confused.
Old Jul4-09, 05:09 PM                  #10
HallsofIvy
PF Mentor
HallsofIvy is Offline:
What is confusing? Do you not know how to integrate? If you know how to integrate, then integrate:
LaTeX Code: \\int \\frac{dv}{-kv^2+ c}= \\int dt
Old Jul4-09, 07:42 PM                  #11
fereak
fereak is Offline:
Yeah, of course I can integrate, by why dv/(-kv2 + c)? Where is that from?
Old Jul4-09, 11:16 PM                  #12
Mentallic
Mentallic is Offline:
LaTeX Code: a=\\frac{dv}{dt}=-kv^2+c
but you can't differentiate -kv2+c with respect to time because there is no time in the equation.
So what you can instead do is use the rule LaTeX Code: \\frac{1}{\\frac{dv}{dt}}=\\frac{dt}{dv} and now we have LaTeX Code: \\frac{dt}{dv}=\\frac{1}{-kv^2+c}
and now we can integrate with respect to velocity.
Old Jul5-09, 08:07 AM                  #13
fereak
fereak is Offline:
OK! But where has -kv2+c come from? Seriously, wtf? How was that expression calculated? How is it relevant?
Old Jul5-09, 09:46 AM                  #14
Mentallic
Ahh so thats what you didn't understand. Well, at least you made it more clear this time
the a=-kv2+c is basically saying that as your velocity increases in any direction, the drag force of the air will increase at a quadratic rate (as expressed by the v2). Think of it logically for a second. Air resistance is fairly negligible at low speeds, i.e. you barely feel still air when you're walking through it, but as your speed increases to a run, it quickly becomes noticeable. When you pop your head out of the car it's very distinct, and even painful. When a space shuttle enters the atmosphere, the friction is profound enough to cause massive heating and creates very large G-forces on the shuttle and astronauts.
Ok, so as you can see, doubling your velocity doesn't necessarily mean twice as much drag force, it seems to be more than that. Now, for some reason (if anyone has deeper knowledge on the subject, please let us know) some had come to the conclusion - probably through experimental data - that the relationship between velocity and drag is a quadratic one.
a=-kv2+c
k>0, some number with a value probably depending on the atmospheric pressure (correct me if I'm wrong, this is a wild guess)
c=gravity, the only force acting when v=0 is gravity, i.e. the drag is negligible.
I hope this makes more sense.
Old Jul5-09, 11:59 AM                  #15
JanClaesen
JanClaesen is Offline:
a=-kv2+c
If c = g, does this mean that this formula is used for calculating the drag on for example rockets?
Since drag force and gravity have the same direction (in this case), is c < 0?
By the way, when do you use this formula, since I always learned that the drag force is -λ*v(t)
Old Jul5-09, 03:33 PM                  #16
tiny-tim
tiny-tim's Avatar
Recognitions:
Red face reality? don't talk to me about reality …
Hi JanClaesen!
In my experience, exam questions are nearly always about drag proportional to v, not v2
whether that represents reality, I've no idea!
image image
Reply
Tags
calculus, drag, kinematics, question, suvat
Thread Tools
Similar Threads for: Kinematics question
Thread Thread Starter Forum Replies Last Post
HELP!!! A question on Kinematics in 2D & 3D? Kudo Shinichi Introductory Physics 3 Sep22-08 02:16 PM
Kinematics question asi123 Introductory Physics 1 May31-08 12:09 PM
kinematics question imy786 Introductory Physics 61 Mar20-07 09:09 AM
a question on kinematics amitchhajer Introductory Physics 7 Aug21-05 02:06 PM
kinematics question bADc Introductory Physics 1 Apr19-05 11:30 AM
Powered by vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
