Acute Angle between two vector-valued functions
  • Thread starter Thread starter SolfegeDuck
    Angle Functions
The discussion revolves around finding the cosine of the angle between two vector-valued functions, specifically focusing on the acute angle formed by their tangent lines. Participants are exploring the appropriate use of the cosine formula involving the dot product and magnitudes of the vectors.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the correct equation for calculating the cosine of the angle and question how to handle the variable "t" present in their vector-valued functions. There is uncertainty about whether to substitute specific values for "t" or to leave it as a variable.
Some participants confirm the use of the cosine formula and provide insights into the dot product and magnitudes. Others are exploring the implications of different values for "t" and whether to treat them as distinct variables for each vector-valued function.
There is mention of a specific point (1,1,3) and different values of "t" for each vector, which raises questions about how to approach the substitution in the context of the problem. The nature of the problem may involve either a specific instance or a general form.
SolfegeDuck
Quick question. I need to find cos [tex]\vartheta[/tex], where [tex]\vartheta[/tex] is the angle (acute) between two vector-valued functions (which are tangent lines).
I think this is relevant:
cos[tex]\vartheta[/tex] = (u dot v)/([tex]\left\|[/tex]u|| * [tex]\left\|[/tex]v||)
Is that the correct equation to use? If so, well, the two equations I'm using both have "t" in them, since they're VVFs. But what do I put in for t? I get the feeling that it's blatantly obvious...Thanks for helping!
Yes, that's the right equation. Dot product is defined as multiplying i, j, and k components of each vector (assuming 3 component vectors) to return a scalar value. |u||v| means multiplying the scalar magnitudes of vector u and v.
Great, thanks! But when I actually do out the equation, I have all of those "t" variables everywhere (2t+1) - (3t^3), etcetera...what do I substitute in for that?
That depends on the question. Either it gives you a specific instance for when the two vectors cross or it wants the angle in general form where t is ambiguous.
The point is (1,1,3). But for u, t = 3, and for v, t = 4. So, do I use one of those t-variables, or go with something else entirely?
It shouldn't be hard to see that you need to use both of them- one applies to u and the other to v. In fact, instead of using t in both functions, it would be better to use, say, t1 for u and t2 for v. Then set t1= 3, t2= 4.
  • · Replies 19 ·
